The Seasonic PRIME PX-2200 PSU is designed for PC users in Europe who need large amounts of power for AI and edge computing tasks. While modern PC gaming rigs have been seen consuming large amounts of power that are not uncommon to reach 600W-1300W, they can pale compared to the needs of an AI system running multiple GPUs combined with large amounts of system memory paired with a power-hungry CPU. Unfortunately, users in the U.S., with its 120V/60 Hz AC have more challenges in providing a simple, easy, solution for powering a rig that could consume 2200 Watts, but in Europe, that’s not as much of an issue with its 200-240V options.
Per Seasonic (via official product page):
- “When selecting a power supply, it’s crucial to estimate the required power for both current and future components in your system. The Seasonic PRIME PX-2200 is a robust power supply capable of safely powering up to four RTX 4090 graphics cards, thanks to its adherence to ATX 3.1 and PCIe 5.1 specifications. Designed for demanding applications such as artificial intelligence and other high-power workloads, this flagship unit from the PRIME series delivers top-tier performance built on high-quality components.”
The PRIME PX-2200 80+ Platinum is expected to launch next month with an MSRP of €579.90€ (Europe) / $499.99 (ROW). It is cooled via a 135mm FDB fan which features digital-hybrid control options for optimal cooling and noise control. With 2 x 8-pin to 12V-2×6 cables, along with 2 x 12V-2×6 connectors, it is capable of powering up to 4x NVIDIA GeForce RTX 4090 GPUs.
Specifications:
- ATX 3.1 and PCIe 5.1
- 80 PLUS® Platinum EU 230 V
- Fully Modular Cabling Design
- Two Native 12V-2×6 Cables
- Two 2×8-pin to 12V-2×6 Cables
- 135 mm Fluid Dynamic Bearing (FDB) Fan
- Digital Hybrid Fan Control
- Highly Reliable Japanese 105°C Aluminum Electrolytic Capacitors
- Micro Tolerance Load Regulation @ 1 %
- MTBF @ 25 °C, excl. fan: 100,000 hours
- Life Expectancy: 50,000 hours at 40 °C, 15 % – 65 % RH
- Cable-free Connection Design
- 12 years warranty
- AC Input: Fixed 230 V
- Protection: OPP, OVP, UVP, OCP, OTP, SCP
- Safety and EMC: cTUVus, TUV, CB, CCC, BSMI, EAC, CE
- Cybenetics Noise and Efficiency Level: TBA
