The Sound Blaster GS5 Is a 60W Soundbar with Full-Range Racetrack Drivers, Adjustable RGB, and a Built-In Port Tube for Optimal Bass
Image: Creative Labs
The Sound Blaster GS5 from Creative Labs is the latest addition to its GS series designed for Desktop computers, consoles, and televisions. With a frequency response of 65-20,000 Hz and an SNR of 85 dB, its 2 x 15W RMS featuring 3.35 x 2.16” full-range racetrack drivers can deliver up to 60W of audio. The Sound Blaster GS5 is designed with a rear port tube for added bass reproduction. Other features include Creative’s SuperWide technology which offers Near Field mode for desktop users and Far Field mode for those listening from a distance. Connectivity support includes Bluetooth 5.3, USB Type C, Optical-in, AUX-in, and a Headphone port.
The Creative App allows users to further configure the Sound Blaster GS5 audio settings, including its RGB lighting which supports up to 16 billion colors. The app is available from Windows, Google, and the Apple app store. An included IR remote provides full control as well. Pre-orders are up for $69.99 with the product launching on October 28.
Specifications (via product page):
  • Speaker Configuration: Soundbar, One-piece
  • Connector Type: Optical-in (TOSLINK), Bluetooth®, 3.5 mm AUX-in, Headphones-out, USB Audio (Type C)
  • Operating Temperature: 0—45°C
  • Recommended Usage: Movies / Music, Gaming
  • Dimensions: 510 x 102.7 x 82.6mm / 20.07 x 4.04 x 3.25 inches
  • Weight (Soundbar): 1.5 kg / 3.3 lbs
  • Cable Length (End-to-end): USB-A to USB-C Cable: 1.5m
  • Frequency Response: 65–20,000 Hz
  • Signal-to-Noise Ratio (SNR): 85 dB
  • Power Output: Soundbar (2 x 15W RMS), Peak Power: 60W, Total System Power: Up to 30W RMS
  • Bluetooth Version: 5.3
  • Profiles: (A2DP) Wireless Stereo Bluetooth*, *Stereo Bluetooth or A2DP profile enables wireless transmission of full stereo sound to other Bluetooth devices. To determine whether your device (notebook, PC, or mobile device) is equipped with A2DP-enabled Bluetooth technology, refer to your device manufacturer’s documentation/website for more information.
  • Operating Frequency: 2402–2480 MHz
  • Operating Range: Up to 10m / 33 ft*, *Measured in open space. Walls and structures may affect range of device.
  • Wireless Codecs: SBC
  • Console Support: PS4/PS5 (Firmware Ver 5.0 or later for PS4, Firmware Version 20.02-2.26.00.00-00.00.00.0.1 or later for PS5 Available USB A port for audio), Nintendo Switch (Switch OS 5.0 or later, Available USB A port for Audio)
