The GeForce RTX 5080, a new Blackwell GPU for gamers and creators that NVIDIA is expected to unveil during next year’s CES event, will deliver lower performance than the current flagship, the GeForce RTX 4090, according to a recent report. The GeForce RTX 5090 and GeForce RTX 5080 are said to be launching in January, while the GeForce RTX 5070 will arrive in February with 12 GB of GDDR7 memory and a 250-watt TDP. Specifications for the initial GeForce RTX 50 Series can be found below.
NVIDIA GeForce RTX 50 Series
| PCB | SKU | FE/AIC | Model | GPU | DRAM | Memory Bus Width | TGP |
| PG144 | 30 | FE | GeForce RTX 5090 | GB202-300 | 32GBGDDR7 | 512 bits | 600W |
| PG145 | 30 | AIC | GeForce RTX 5090 | GB202-300 | 32GBGDDR7 | 512 bits | 600W |
| PG144 | 45 | FE | GeForce RTX 5080 | GB203-400 | 16GBGDDR7 | 256 bits | 400W |
| PG147 | 45 | AIC | GeForce RTX 5080 | GB203-400 | 16GBGDDR7 | 256 bits | 400W |
| PG147 | 70 | AIC | GeForce RTX 5070 | GB205-xxx | 12GBGDDR7 | 192 bits | 250W |
…the overall performance of the NVIDIA GeForce RTX 5080 cannot compete with the NVIDIA GeForce RTX 4090. Therefore, the original plan of the GeForce RTX 5080 D may be aborted, but the NVIDIA GeForce RTX 5090 is bound to have a “D” The version plan is still in the early stages of planning at this stage, so it depends on NVIDIA’s subsequent overall plan.
