G.SKILL Launches Trident Z5 CK Series DDR5-9600 CU-DIMM Memory with Built-In Clock Driver for Improved Stability in High-Speed Memory Operations
Image: G.SKILL
G.SKILL has announced that its Trident Z5 CK and Trident Z5 CK RGB series DDR5 CU-DIMM memory kits will be rolling out to authorized G.SKILL distributors and retailers in October 2024. An official trailer and launch specifications for the new memory, which feature a built-in clock driver (CKD) for what G.SKILL says is improved stability in high-speed memory operations, can be found below.
Image: G.SKILL
The Trident Z5 CK and Trident Z5 CK RGB series is built on the new CU-DIMM standard, which introduces a built-in clock driver (CKD) chip on the memory module. Designed to strengthen signals between the CPU and memory IC chips, the CKD helps in improving stability in high-speed memory operations.
Continuing with the design language of the flagship performance Trident Z5 family, the Trident Z5 CK and Trident Z5 CK RGB series features heatspreader with a sleek mirrored black finish, topped with a piano black top bar or a semi-translucent RGB light bar, respectively, to add a refined aesthetic to your PC build.
