Phanteks Introduces Glacier EZ-Fit Water Cooling System for Streamlining the Water Cooling Process
Image: Phanteks
(PR) At Phanteks, we are dedicated to pushing the boundaries of innovation in the enthusiast PC market. Today, we are proud to unveil our latest breakthrough: the Glacier EZ-Fit water cooling system. Designed to streamline the water cooling process, this all-new system offers unmatched ease-of-use, flexibility for custom loop design, and cutting-edge performance.
Gone are the days of complicated fittings and endless shopping lists. With Glacier EZ-Fit, fittings are integrated directly into the cooling components, eliminating the need for separate purchases. Whether you’re using hard tubing or soft tubing, the EZ-Fit system seamlessly allows both types to be used within the same loop—giving enthusiasts more creative freedom and reducing setup complexity.
Precision Engineering and Premium Materials
Crafted from premium 100% copper, cast acrylic, and rigid aluminum alloys, Glacier EZ-Fit products are engineered using advanced CNC machinery for ultimate precision and maximum performance. This dedication to quality ensures the Glacier EZ-Fit system delivers top-tier cooling while maintaining sleek, durable construction.
Key Features of the Glacier EZ-Fit Water Cooling System:
  • Integrated Fittings: Built into blocks, radiators, and reservoirs for a simplified assembly.
  • Interchangeable Tubing: Supports both 16mm hard tubing and soft tubing within the same loop.
  • Simplified Shopping: No need for multiple fitting types; everything is included.
  • Premium Materials: Components made from 100% copper, cast acrylic, and rigid aluminum alloys.
  • Precision Engineering: CNC-machined in Phanteks’ own facility for superior craftsmanship.
Availability:
North America – Available Now
Europe – Mid November
Image: Phanteks
The Glacier EZ-Fit system redefines PC water cooling by providing enthusiasts with a premium, streamlined, and customizable cooling experience. By combining the highest quality materials with an intuitive design, Phanteks ensures the Glacier EZ-Fit delivers industry-leading performance without the hassle.
