(PR) GAMDIAS, a global leader in premium PC gaming hardware, proudly introduces the ATLAS 1st Series PC cases, designed to meet the diverse needs of gamers and PC enthusiasts. “The ATLAS 1st Series brings ‘Gaming Art in Motion’ to life, with dual side windows showcasing the beauty of internal components,” said Stimson Wang, CEO of GAMDIAS Technology. Each model—the ATLAS P1, ATLAS M1, and ATLAS E1—reflects our commitment to creating an immersive environment where gamers of all levels can perform at their best.
COMMON FEATURES ACROSS THE ATLAS 1st SERIES
All models in the ATLAS 1st Series come with front and side tempered glass panels, ensuring seamless visuals and a clear view of your components. They are equipped with a digital display for real-time system monitoring, including CPU, GPU, and ambient temperature, adjustable via ZEUS CAST software and a monitor mode switch. Each case includes 120mm ARGB fans, with the M1 and P1 featuring PWM functionality and pre-installed PWM ARGB fan hub for optimized airflow and cohesive lighting. Connectivity is comprehensive, with USB 3.0, fan LED control, monitor mode switch, and integrated audio jacks. The M1 and P1 models also feature a USB 3.2 Gen 2 Type-C port for high-speed data transfer.
POWERFUL VENTILATION
Engineered for superior airflow, the ATLAS 1st Series ensures your system remains cool during intense gaming sessions. Each model features optimized ventilation designs for maximum air intake and exhaust. The built-in fans in each case operate silently while delivering high airflow. In the M1 and P1 models, PWM functionality allows for dynamic fan speed adjustments based on thermal needs, enhancing cooling efficiency and noise reduction.
ATLAS P1: EXQUISITE DESIGN, EXTREME FUNCTIONALITY
The ATLAS P1 is the flagship model, offering advanced features and support for high-performance builds. It accommodates up to 420mm radiators at the side and top, with space for 455mm VGA cards in both horizontal and vertical orientations. Available in a sophisticated black edition, the P1 includes a one-touch release mechanism for quick hardware access and a dual-hinged, detachable tempered glass side panel. It also features a unique magnetic modular digital display that can be positioned for optimal viewing of system information. Additionally, the P1 supports connector-hidden motherboards (BTF motherboards), allowing cables to plug in from the back for a flawless view and enhanced PC setups.
ATLAS M1: FUNCTIONALITY WITH SEAMLESS VISUALS
Balancing size and performance, the ATLAS M1, available in matte black and snow white, supports 360mm or 280mm radiators at the top and a 240mm radiator at the side, with room for 410mm VGA cards. It also features a simple clasp mechanism for quick hardware access. The ATLAS M1 includes three 120mm PWM ARGB fans and a PWM ARGB fan hub, delivering exceptional lighting and fine-tuned airflow.
ATLAS E1: SEAMLESS AESTHETICS
The ATLAS E1 is the most compact model, designed for efficient builds without sacrificing style. It supports 240mm radiators at the top and 340mm VGA cards, making it ideal for small form factor setups. Available in black and snow white, the ATLAS E1 features a simple clasp mechanism for easy removal of the front and side tempered glass panels, ensuring effortless building and maintenance.
Experience the pinnacle of PC case design and functionality with the ATLAS 1st Series from GAMDIAS. Elevate your gaming setup and build your dream rig with these versatile and stylish cases.
KEY FEATURES FOR ATLAS P1
- Seamless Tempered Glass Display
- 8 Slot Horizontal and Vertical GPU Holder
- 4 Built-in 120mm ARGB PWM Fans
- Pre-installed 8-port ARGB PWM Fan Hub
- One-touch Release Mechanism
- Customized Monitor for System Information
- BTF Motherboards Support
- Compatible with 455mm GPU
- Gen 2 Type-C Interface
- Magnetic Dust Filter
KEY FEATURES FOR ATLAS M1
- Matte Black and Snow White Edition
- Perforated Air Vent PSU Chamber
- 3 Built-in 120mm ARGB PWM Fans
- Fits Mini-ITX, Micro-ATX and ATX motherboards
- Pre-installed 6-port ARGB PWM Fan Hub
- Compatible with 410mm GPU
KEY FEATURES FOR ATLAS E1
- 3 Built-in 120mm ARGB Fans
- Compatible with 340mm GPU
MSRP:
- ATLAS P1: $144.99
- ATLAS M1: $89.99
- ATLAS M1 WH: $94.99
- ATLAS E1: $74.99
- ATLAS E1 WH: $79.99
