ASRock Launches Intel Arc B580 Steel Legend 12GB OC, B580 Challenger 12GB OC, and B570 Challenger 10GB OC Graphics Cards
Image: ASRock
(PR) ASRock, the global leading manufacturer of motherboards, graphics cards, mini PCs, gaming monitors and power supply units, today launches the all-new Intel Arc B-Series graphics cards, including Steel Legend and Challenger products based on Intel Arc B580 and Intel Arc B570 Graphics, which are born to shine your PC builds!
Based on the latest Xe2-HPG architecture, Intel Arc B-Series GPUs are designed for high performance gaming at 1440p and 1080p with AI upscaling and ray tracing. They are equipped with cutting-edge features: Intel Xe Super Sampling technology (XeSS), which takes your gaming experience to the next level with AI-enhanced upscaling for higher performance and high image fidelity. Intel XeSS Frame Generation and Intel Xe Low Latency technologies make your games play smoother and more responsive. Intel Xe Matrix eXtensions (XMX) AI engines accelerate AI-enhanced gaming, creation, and media generation. The Advanced Media Engine accelerates your content creation with two full-featured media transcoders to speed up the media exporting across the most popular formats including AV1.
In addition, ASRock’s Intel Arc B-Series graphics cards support various exclusive features such as the Striped Ring/Axial Fan, Ultra-fit Heatpipe, Stylish Metal Backplate, and the Polychrome SYNC technologies to deliver outstanding cooling efficiency, solid construction, and fancy ARGB LED light effects. With all these premium specifications, exclusive features and brand-new outlook design, ASRock’s Intel Arc B-Series graphics cards become great choices for gamers, creators, and system integrators.
ASRock Intel Arc B580 Steel Legend 12GB OC Graphics Card
ASRock Intel Arc B580 Steel Legend 12GB OC graphics card offers a Graphics Clock up to 2800MHz, and features 12GB GDDR6 memory running at 19Gbps. It is equipped with the triple fan design and other technologies such as Striped Ring Fan and Ultra-fit Heatpipe to provide outstanding cooling performance. The Stylish Metal Backplate can strengthen the structure and prevent the board from bending. The ARGB fans and ARGB LED light panel combined with Polychrome SYNC software allows users to fully customize and control their lighting effects. With all the unique features, the white color scheme and the factory pre-overclocked GPU clock settings make ASRock’s Intel Arc B580 Steel Legend 12GB OC graphics card perfectly crafted for white-themed PC builders.
Image: ASRock
ASRock Intel Arc B580 Challenger 12GB OC Graphics Card
ASRock Intel Arc B580 Challenger 12GB OC graphics card offers a Graphics Clock up to 2740MHz, and features 12GB GDDR6 memory running at 19Gbps. It is equipped with a dual-fan cooler with the exclusive Striped Axial Fan and Ultra-fit Heatpipe to provide better heat dissipation. The Stylish Metal Backplate strengthens the structure. The compact dual-slot design maximizes compatibility with various chassis on the market. The factory pre-overclocked settings deliver improved performance. The new LED Indicator make the graphics card looks fancy. These practical designs enable ASRock’s Intel Arc B580 Challenger 12GB OC graphics card to better meet the needs of system integrators and mainstream users.
Image: ASRock
ASRock Intel Arc B570 Challenger 10GB OC Graphics Card
ASRock Intel Arc B570 Challenger 10GB OC graphics card offers a Graphics Clock up to 2600MHz, and features 10GB GDDR6 memory running at 19Gbps. It is equipped with a dual-fan cooler with the exclusive Striped Axial Fan and Ultra-fit Heatpipe to provide better heat dissipation. The Stylish Metal Backplate strengthens the structure. The compact dual-slot design maximizes compatibility with various chassis on the market. The factory pre-overclocked settings deliver improved performance. The new LED Indicator make the graphics card looks fancy. These practical designs enable ASRock’s Intel Arc B570 Challenger 10GB OC graphics card to better meet the needs of system integrators and mainstream users.
Image: ASRock
Source (1, 2, 3)
