Phanteks Launches G400A Mid-Tower Chassis with up to 10 Fan Mounts and Support for Rear-Side Connector ATX Motherboards
Image: Phanteks
(PR) Phanteks is excited to introduce the G400A, a next-generation mid-tower chassis that builds on the success of the P400A. Designed with gamers and PC builders in mind, the G400A delivers exceptional airflow, efficient cable management, and a clean, modern aesthetic. Its redesigned, spacious interior supports the largest graphics cards and enhances cooling potential, making it ideal for high-performance builds.
With up to 10 fan mounts, support for 140mm fans, and space for a 360mm top radiator, the G400A is engineered to handle demanding systems. A sleek, cable-free rear-side connector layout further ensures a neat, organized build while maximizing airflow.
Key Features of the G400A Mid-Tower Chassis
  • Rear-Side Connector ATX Mainboard Support: Conceals connectors for a streamlined, cable-free look. Compatible with MSI BTF and ASUS Project Zero ATX mainboards.
  • Seamless Compatibility: Fully compatible with the Phanteks NexLinq App and Hub for easy control and customization.
  • Redesigned Front Panel: 45% open surface area for improved airflow intake.
  • Clean Front Inlet Design: Directs focused airflow to critical components and reduces turbulence.
  • 4x M25-140 Gen2 DRGB Fans Included: High-performance cooling with stunning D-RGB lighting.
  • Flexible Fan Support: Supports up to 7x 120mm or 6x 140mm fans.
  • Spacious GPU Compatibility: Support for largest graphics cards without compromise.
  • Built-In D-RGB Strip: Adds ambient lighting to enhance the internal components.
  • Dedicated Cable Management Tool: Cable tray with Velcro straps helps organizes cables for a clean look.
The G400A offers robust cooling, ample space, and modern aesthetics, making it the ideal choice for gamers and creators seeking a versatile, high-performance PC case.
Available Now: G400A Chassis (Black/White) $99.99 |€99.90 | £84.90.
