ASRock Announces Budget-Friendly Challenger Series Light Gaming Monitors CL25FFA and CL27FFA with High-Quality IPS Panels
Image: ASRock
(PR) ASRock, the global leading manufacturer of motherboards, graphics cards, mini PCs, gaming monitors and power supply units, today launches two light gaming monitors, the CL25FFA and CL27FFA. In competitive gaming, image quality and responsiveness are critical. Standard commercial monitors often fall short of meeting gamers’ needs, which is why the CL25FFA and CL27FFA were developed. With a 120Hz refresh rate, these monitors deliver an impressive balance of performance and affordability, offering gamers a superior alternative to commercial monitors.
120Hz Refresh Rate for Smooth Visuals
The CL25FFA and CL27FFA are equipped with a 120Hz refresh rate, significantly outperforming the standard 60Hz refresh rate of most commercial monitors. This means double the frames per second, ensuring smoother gameplay. Whether it’s high-speed FPS games or precision-dependent MOBA battles, these monitors provide a competitive edge, enabling gamers to stay ahead.
Image: ASRock
IPS Panels with FHD Resolution: Enhanced Color and Viewing Angles
Unlike typical commercial and home monitors that often use lower-cost panel technology resulting in inaccurate colors and narrow viewing angles, the CL25FFA and CL27FFA feature high-quality IPS panels. These panels deliver a 178° wide viewing angle and Full HD resolution, ensuring vivid, true-to-life colors from every angle. Even during extended use, the monitors maintain consistent performance, preventing color distortion from compromising the gaming experience.
Image: ASRock
A Budget-Friendly Choice for Gamers
Positioned as “light gaming” monitors, the CL25FFA and CL27FFA offer core features comparable to high-end gaming monitors while maintaining an accessible price point. They empower every gamer to upgrade their setup effortlessly without compromising on performance or budget. Perfect for beginners or daily use, these monitors deliver unparalleled smoothness and visual delight.
*Product specifications are subject to change without notice.
For more information, please visit:
Challenger CL25FFA Gaming Monitor
https://www.asrock.com/Monitors/Challenger/CL25FFA/index.asp
Challenger CL27FFA Gaming Monitor
https://www.asrock.com/Monitors/Challenger/CL27FFA/index.asp
