(PR) G.SKILL International Enterprise Co., Ltd., the world’s leading brand of performance overclock memory and PC components, is announcing the release of low latency DDR5-6400 CL30-39-39-102 memory specification in high-capacity kit configurations, up to 96GB (2x48GB) kit capacity. This high performance memory kit specification will be available under the Trident Z5 RGB and Trident Z5 Royal series, with Intel XMP 3.0 memory overclock profile support.
High-Performance Memory for Intel Z890 Platform
The G.SKILL DDR5-6400 CL30 memory kit at 96GB (2x48GB) combines high-capacity and low-latency to enable higher performance for memory intensive platforms and uses. The screenshot below shows this 96GB (2x48GB) memory kit operating at DDR5-6400 CL30-39-39-102 with the ASUS ROG Maximus Z890 Hero motherboard and Intel Core Ultra 7 265K desktop processor.
Demonstrating DDR5-6400 CL30 96GB (2x48GB) on AMD AM5 Platform
Under extensive research and development, G.SKILL is also demonstrating the possibility of this low-latency, high-capacity memory kit running on the new AMD Ryzen 9000 series CPU and AMD X870 chipset motherboard. The following screenshot showcases a 96GB (2x48GB) memory kit operating at DDR5-6400 CL30-39-39-102 with the ASUS ROG Crosshair X870E Hero motherboard and AMD Ryzen 7 9800X3D desktop processor.
Overclock Profile Support & Availability
This new DDR5-6400 CL30 specification supports the Intel XMP 3.0 memory overclock profile under the Trident Z5 RGB and Trident Z5 Royal memory series for easy memory overclocking via the motherboard BIOS on supported platforms. In addition to the large 96GB (2x48GB) kit capacity, 64GB (2x32GB) and 48GB (2x24GB) capacity kits are also slated for release. These memory kits will be rolling out to G.SKILL worldwide distribution partners starting in Q1 2025.
