Thermaltake Launches Toughpower TF3 1300W – TT Premium Edition ATX 3.1 and PCIe Gen 5.1 Ready 80 PLUS Titanium PSU with Support for NVIDIA GeForce RTX 50 Series GPUs
Image: Thermaltake
(PR) Thermaltake, a leading PC DIY brand for premium hardware solutions, is proud to launch the Toughpower TF3 1300W – TT Premium Edition, the 80 PLUS Titanium certified and full modular PSU that is designed to power up high-performance and overclocking systems. The Toughpower TF3 1300W is built to comply with the ATX 3.1 specification and comes with PCIe Gen 5.1 connectors, it ensures superior reliability and future-ready compatibility for high-end hardware including the latest RTX50 series graphics cards.
The Toughpower TF3 1300W meets ATX 3.1 standards, supporting up to 200% total power excursion, 300% GPU power excursion, and reaches 60% efficiency at low load. Its two native PCIe 12V-2X6 modular interfaces are compatible with advanced PCIe 12+4pin connectors, providing up to 600W for the next-gen PCIe 5.1 graphics cards. To reduce installation errors, the 12+4pin cable comes with a dual-color design in matcha green and black, allowing users can easily verify proper connections.
With maximum graphics card compatibility, the Toughpower TF3 1300W supports various NVIDIA and AMD graphics cards. This power supply incorporates 8-pin PCIe cables for AMD & RTX series graphics cards, it also features two PCIe 12V-2X6 connectors for RTX 50 & 40 series cards which are compatible with PCIe Gen 5.1 connectors, tailored to different connection needs of graphics cards.
Image: Thermaltake
Designed for overclocking enthusiasts, the OCM switch on the Toughpower TF3 1300W allows users to effortlessly optimize system’s performance. By default, the power supply operates in Multi-Rail mode with Over Current Protection (OCP) to ensure maximum safety. After a simple press of the OCM switch, the Toughpower TF3 1300W can transit to the single 12V rail mode, unleashing it maximum capability. Additionally, the Toughpower TF3 1300W is equipped with a Thermaltake customized cooling fan, effectively prevent the system from overheating.
The Toughpower TF3 1300W is made with 100% high quality Japanese 105°C/221°F electrolytic capacitors, providing advantageous durability and reliability. It is built with the <30mV low ripple noise design, voltage regulation <±2%, and 17ms and up hold up time, ensuring its stability. This power supply is compatible with 80 PLUS Titanium certification, allowing lower power loss through its high efficiency of up to 94%.
For those seeking a PSU that can handle the demands of high-specification systems, the Toughpower TF3 1300W is an outstanding choice. Built to ATX 3.1 standards with PCIe 12V-2×6 support and 80 PLUS Titanium efficiency, it unlocks the full potential of your high-end components, making it a must-have for overclockers and performance enthusiasts.
Features of the Toughpower TF3 1300W
Fully Compatible with ATX 3.1 Standards
The Toughpower TF3 1300W is fully compatible with ATX 3.1 specifications which supports up to 200% power excursion, reaches 60% efficiency at low load and complies with required power supply timing standards.
PCIe Gen 5.1 Ready: Dual Native 12V-2×6 Connectors
The Toughpower TF3 1300W features two native PCIe 12V-2×6 connectors and includes two PCIe 12+4 pin cables, providing powerful and stable performance to meet the power demands of next-generation PCIe Gen 5.1 graphics cards.
The wattage marked on the PCIe 12V-2X6’s cable is the recommended wattage. (Ref. Intel design guideline)
The native PCIe 12V-2X6 connectors of the Toughpower TF3 1300W can deliver up to 600W for PCIe 5.1 graphics cards.
Dual-Color 12+4pin Cable
The cable connectors feature a dual-color design with a Matcha Green color scheme, reducing installation errors and helping users easily determine whether the cables are properly connected.
Made to Comply with the Latest Graphics Cards
As the power consumption of graphics cards increase, so has their demand for power. The Toughpwer TF3 1300W is designed to support NVIDIA and AMD graphics cards, it supports 8-pin PCIe cables for AMD & RTX series graphics cards, it also comes with 2 x PCIe 12V-2X6 connectors for RTX 50 & 40 series cards that need a PCIe Gen 5.1 connector, ready to supply the graphics cards according to their different ways of connections.
Unlock Peak Overclocking Performance: Manual Overclocking Mode Switch
The OCM switch gives you the power to optimize your system’s performance with ease. By default, the power supply operates in Multi-Rail mode with Over Current Protection (OCP) to ensure maximum safety for your components. For overclocking enthusiasts, a simple press of the OCM switch transitions the power supply to Single 12V rail mode, unleashing enhanced power delivery when you need it most.
80 PLUS Titanium Certified
80 PLUS Titanium certification means the Toughpower TF3 converts power efficiently, saves energy through its high efficiency up to 94%, resulting in lower power loss and heat buildup inside the power supply.
Thermaltake Customized Cooling Fan
The Toughpower TF3 1300W features the Thermaltake customized cooling fan, and it is designed with specially tuned fan blades to push air further.
30mV Low Ripple Noise Design
Top-end build quality with low ripple noise. All ripples are lower than 30mV on +12V, +5V or +3.3V from 0% to 100% load to ensure a stable operation and keep your performance-critical components to function reliably for longer.
Extremely Strict Voltage Regulation <±2%
The voltage regulation is more strict than Intel’s standard +5%,-7% for major rails and ±10% for -12V, is set to no more than ±2% for major rails, providing steady clean power through exceptional voltage stability.
17ms and up Hold Up Time
During a power interruption, your computer might shut down or reboot. We make sure that the TF3 1300W will deliver at least 17ms at 80% workload, without system reboot or resetting.
More Stable than Ever
100% high quality Japanese 105°C/221°F electrolytic capacitors provides great durability as well as offering the highest stability, while remaining reliable.
High-Class Technologies
The use of LLC and DC to DC circuit design provides very stable operation and enhanced voltage regulation.
Fully Modular Low-Profile Etched Flat Cables
Offers cable selection for users while powering the system at an advantageous voltage. Low-profile etched flat cables make cable management easier, reduces clutter and increases airflow inside the chassis.
Built-in Industrial Grade Protection
To protect the hardware, Toughpower TF3 1300W is built with industry grade protections: OCP(Over Current Protection), OVP (Over Voltage Protection), UVP(Under Voltage Protection), OPP(Over Power Protection), SCP(Short Circuit Protection), OTP(Over Temperature Protection).
Intel C6/C7 States Ready
Toughpower TF3 1300W has been optimized to work with all generations of Intel’s processors to achieve maximum energy savings.
Toughpower TF3 1300W:
$ 259.99 / €264.90
(prices may vary per region)
