GAMDIAS Launches the ATLAS P2 CG Curved Glass Panoramic Case with Fish-Tank-Inspired Design, Embedded Display for Real-Time System Monitoring, and BTF Motherboard Support
Image: GAMDIAS
(PR) GAMDIAS, a premier brand in high-performance gaming PC hardware, is excited to announce the launch of the ATLAS P2 CG curved glass panoramic case. As the first product launch of 2025, the case embodies GAMDIAS’s annual slogan, “GAMING REIMAGINED,” redefining gaming setups with a sophisticated design and unmatched functionality. “The ATLAS P2 CG reflects our vision for 2025, offering gamers a seamless blend of cutting-edge design and exceptional performance that will transform their gaming experience,” said Stimson Wang, CEO of GAMDIAS. Part of the highly acclaimed ATLAS series, the case features a striking fish-tank-inspired design with a seamless one-piece curved glass panel and an integrated system display, engineered to deliver limitless potential alongside a refined visual experience.
IMMERSIVE PANORAMIC VIEW
The ATLAS P2 CG case features a stunning 270-degree curved tempered glass panel, offering an immersive panoramic view of the interior. This innovative design eliminates corner obstructions, creating a seamless showcase of internal components. Additionally, the case also supports connector-hidden motherboard (BTF motherboard), enabling cables to plug in from the rear for a clean and flawless front appearance.
Image: GAMDIAS
POWERFUL VENTILATION
Designed to deliver exceptional cooling performance, the ATLAS P2 CG ensures your system remains cool during intense gaming sessions. This mid-tower case comes equipped with four 120mm PWM ARGB fans, three at the side and one at the rear exhaust, and an 8-port PWM ARGB fan hub, allows for easy management and synchronization. This setup enables cohesive lighting effects and ensures quiet, high-performance operation.
Image: GAMDIAS
ADVANCED SYSTEM MONITORING WITH ZEUS CAST SOFTWARE
The ATLAS P2 CG features an embedded display for real-time system monitoring, providing critical information such as CPU, GPU, and ambient temperatures. Users can easily switch between CPU, GPU, ambient (AMB), and off modes through the intuitive I/O port controls. With GAMDIAS’s ZEUS CAST software, users can customize display settings to enhance their system monitoring experience, ensuring critical data is always accessible.
Image: GAMDIAS
ENHANCED CONNECTIVITY, COMPATIBILITY, AND ACCOMMODATION
The ATLAS P2 CG enhances functionality with a user-friendly I/O interface, including a USB 3.2 Gen 2 Type-C port for ultra-fast data transfers, a USB 3.0 port, fan LED controls, and additional audio connectivity. It supports top-tier cooling solutions with space for a 360mm radiator on the top and multiple fan configurations across the side, bottom, rear, and top panels. With support for ATX motherboards, VGA cards up to 430mm in length, and PSUs up to 220mm, the ATLAS P2 CG ensures compatibility with a wide range of components. Comprehensive cable management solutions further guarantee a clean, organized, and professional build.
Image: GAMDIAS
KEY FEATURES
● Immersive Curved Tempered Glass Display
● Perforated Vents for Optimal Ventilation
● 4 Built-in 120mm PWM ARGB Fans
● Pre-installed 8-port PWM ARGB Fan Hub
● Customized Monitor for System Information
● Supports BTF Motherboards
● Compatible with 430mm GPU
● Gen 2 Type-C Interface
● Magnetic Dust Filter
