LIAN LI Reveals Upcoming Products at 2025 Digital Expo, Including Three New LANCOOL Cases, a Rotatable PSU, and Vertical GPU Bracket
Image: LIAN LI
(PR) LIAN LI Industrial Co. Ltd., a leading manufacturer of chassis and PC accessories, will premiere the LIAN LI 2025 DIGITAL EXPO at 9am EST on February 7th, on YouTube. This two-part video series reveals updates to prototype and upcoming products, including cases, AIO liquid coolers, fans, power supplies, and more. Featured products are the LANCOOL 217, LANCOOL 207 Digital, LANCOOL 4, and the O11D MINI V2 cases. Additional innovations include the RS Series rotatable PSU, universal screen and mount, Hydroshift II LCD-C 360R AIO, UNI FANS, and a new vertical GPU bracket.
LANCOOL 217
Image: LIAN LI
The LANCOOL 217 showcases real wood accents and comes with five pre-installed fans. This includes two 170mm front fans that are tool-less height-adjustable, two 120mm GPU cooling fans with reversed blades positioned over the PSU shroud, and a 140mm fan located at the back. Its dual PSU mounting options provide added flexibility for cable management. The case is offered in two variations: black with dark wood accents and white with light wood accents. Prices begin at $119.99.
LANCOOL 207 Digital
Image: LIAN LI
Based on the successful launch in October 2024, which introduced a front-mounted PSU that’s rotated 90 degrees, the LANCOOL 207 Digital adds a 6-inch LCD screen with customizable displays powered by L-Connect 3, alongside four pre-installed non-RGB fans for excellent cooling performance. Prices begin at $109.99.
LANCOOL 4
Image: LIAN LI
The LANCOOL 4 joins the LANCOOL series with its modular design and various cooling options. It features interchangeable front and top mesh panels, both of which can be swapped for a supplied tempered glass panel. Additionally, the adjustable motherboard tray and movable PSU chamber offer remarkable flexibility, each promoting distinct airflow routes and hardware compatibility. The case supports up to 12 fans and accommodates various cooling setups for both air and liquid systems.
O11D MINI V2
Image: LIAN LI
The O11D MINI V2 enhances the O11D MINI’s triumph with a space-efficient dual-chamber design that supports ATX motherboards. Just 2 liters larger than its predecessor, it accommodates standard ATX motherboards, back-connect ATX motherboards, and 360mm radiators on top, up to 60mm thick without requiring an offset bracket. This includes support for Hydroshift Series AIOs in M-ATX mode. The GPU cooling has been improved with a bottom fan bracket angled at 10 degrees. Moreover, the O11D MINI V2 can now fit ATX-size PSUs due to a protruding mesh filter window on the right panel. The I/O module offers flexibility, allowing it to be placed at either the top or bottom of the case.
RS Series Rotatable PSU
Image: LIAN LI
The RS Series PSU features a power cord port that can rotate 90 degrees toward the side of the PSU. This design allows for installation in a rotated position, enhancing cable management and making it easier for users to access the power cable connections without needing an extension cord. Furthermore, the 24-pin motherboard port has been moved from the main port side to both sides, which creates more space, enhances accessibility on the primary port side, and allows for a detachable hub that can provide extra USB connections. The RS Series rotatable PSU is offered in 850W, 1000W, and 1200W models, all with 80 PLUS Gold certification.
Universal Screen and Mount
Image: LIAN LI
The Universal Screen is an 8.8-inch LCD with a resolution of 1920×480 pixels, a 60Hz refresh rate, and a brightness of up to 500 nits. The screen features a hinged mounting bracket, offering adjustable viewing angles and flexible placement options. It can be mounted magnetically to metallic surfaces or secured to 120mm or 140mm fans using standard screws. Additionally, a sliding mechanism allows users to reposition the screen for versatile placement. Seamlessly integrated with LIAN LI’s L-Connect software, the Universal Screen enables the customization of animations, system data, and personalized content.
Hydroshift II LCD 360R
Image: LIAN LI
The Hydroshift II LCD-C 360R AIO cooler, with its slimmer radiator, now offers enhanced compatibility with PC cases. Its 2.1-inch LCD screen, situated on the pump block, boasts a 60 Hz refresh rate and up to 500 nits brightness, further amplified by a thin ARGB strip. Users can control the LCD and ARGB features in three ways: offline or manual control by rotating the AIO pump block; wireless control with limited features; or wired control via L-Connect 3 for full feature access. A sliding clip mechanism ensures a neat appearance with post-installation tube alignment adjustments. The AIO is equipped with redesigned UNI FANs featuring non-RGB PBT blades and wireless ARGB control for optimal cooling efficiency.
UNI FAN SL-INFINITY Wireless
Image: LIAN LI
The UNI FAN SL-INFINITY Wireless features a redesigned 4-wire receiver that ensures seamless motherboard fan speed control, enabling compatibility with PWM functionality and L-Connect’s MB RPM SYNC mode. If the signal is lost, the fans automatically default to the settings in the motherboard’s BIOS or software. The SL-INF Wireless receiver is also backward compatible with SL and TL Wireless models.
The lighting customization allows for three independently controllable zones. These zones include central fan blades with an infinity mirror effect and dual-layer edge infinity mirrors that have a tapered design on one side and a rectangular design on the other. The receiver can be mounted on either end of the fan, allowing users to configure the visible side to suit their build.
Image: LIAN LI
The new Vertical GPU Kit features five adjustable mounting positions to cater to various aesthetic preferences and airflow requirements. Users can opt for standard vertical placement, a lower position for better clearance, or a tilted angle that enhances the visibility of the GPU’s design. The tilting options allow for angling the GPU towards either the side panel or motherboard, showcasing the hardware beautifully. Designed to support modern GPUs, this kit includes options for PCIe 4.0 and 5.0 riser cables.
To catch the full 2025 DIGITAL EXPO, make sure to subscribe to the LIAN LI YouTube channel (here).
