Star Wars Outlaws Adds Support for DLSS 4 with Multi Frame Generation for NVIDIA GeForce RTX 50 Series GPUs, as Well as an Update to PSSR on PS5 Pro
Image: Ubisoft
(PR) A patch has just been deployed for Star Wars Outlaws across all platforms!
It brings support for NVIDIA 50 series GPUs on PC and an update to PSSR on PS5 Pro.  You can find the complete list of changes below.
If you’d like to make the team aware of any bugs you’re experiencing, be sure to check out our Bug Reporter tool that allows you to track the status of existing issues and raise new ones!
Once again, thank you for your support and enthusiasm – see you in the Outer Rim!
PATCH DETAILS (version 1.0.5.1)
  • PlayStation 5: 1.93 GB (version 01.005.001 / 7641097.TU5)
  • Xbox Series X|S:  3.65 GB (version 1.0.5.1 / 7641097.TU5)
  • PC (Ubisoft Connect):  3.30 GB (version 1.0.5.1 / 7711640.TU5)
  • Steam: 3.30 GB (version 1.0.5.1 / 7711640.TU5)
FULL PATCH NOTES
Star Wars Outlaws on PC now features DLSS 4 with Multi Frame Generation for GeForce RTX 50 series, which boosts FPS by using AI to generate up to three frames per traditionally rendered frame. DLSS 4 also introduces faster single Frame Generation with reduced memory usage for RTX 50 and 40 Series, and new transformer AI models for DLSS Ray Reconstruction, Super Resolution, and DLAA for all GeForce RTX GPUs, which enhances stability, lighting, and detail in motion.
Streaming
  • Fixed a crashing issue on streaming platforms when travelling to Renpalli Station
PC
  • Added support for NVIDIA series 5 GPUs
PS5
  • PSSR has been updated to the latest version for PS5 Pro users
All platforms
  • Fixed an issue where Kay could not dismount the speeder when on a steep incline
  • Fixed an issue where audio from overhead ships would be louder than expected
About Star Wars Outlaws
Experience the first-ever open world Star Wars game, set between the events of The Empire Strikes Back and Return of the Jedi. Explore distinct locations across the galaxy, both iconic and new. Risk it all as Kay Vess, a scoundrel seeking freedom and the means to start a new life, along with her companion Nix. Fight, steal, and outwit your way through the galaxy’s crime syndicates as you join the galaxy’s most wanted.
