(PR) EK, the premium liquid cooling gear manufacturer, is proud to introduce EK-Quantum Vector³, our latest line of high-performance water blocks designed to provide the ultimate liquid cooling solution for NVIDIA GeForce RTX 5090 & RTX 5080 Series GPUs.
Unmatched Performance and Cooling Efficiency
The EK-Quantum Vector³ RTX 5090 & RTX 5080 water blocks deliver high-performance liquid cooling, premium aesthetics, and precision engineering, ensuring ultra-low temperatures and maximum performance.
Compatibility and Supported NVIDIA GeForce RTX 50 Series GPUs
The EK-Quantum Vector³ water blocks will be available for a wide range of NVIDIA RTX 50 Series GPUs, ensuring excellent compatibility and cooling performance for both Founders Edition and AIB models, including:
- ASUS ROG Astral GeForce RTX 5090
- ASUS ROG TUF GeForce RTX 5090
- ASUS ROG Astral GeForce RTX 5080
- ASUS ROG TUF GeForce RTX 5080
- NVIDIA GeForce RTX 5090 Founders Edition
- GIGABYTE AORUS, WINDFORCE & EAGLE GeForce RTX 5090
- MSI SUPRIM, GAMING X & VENTUS RTX 5090
- Other major partner models (to be announced)
We are continuously expanding our lineup to support the most popular custom PC builds. Stay tuned for further updates as more models become available!
Next-Gen Cooling for NVIDIA RTX 50 Series GPUs
The EK-Quantum Vector³ RTX 5090 & RTX 5080 water blocks maximize cooling efficiency with an improved structure, expanded fin array, and optimized coolant flow paths. These blocks actively cool the GPU core, VRAM, and power stages while passively cooling PCB hotspots through a custom backplate—ensuring optimal performance.
Premium Aesthetics and Build Quality
Vector³ water blocks feature high-quality materials, a sleek, modern design, and an optimized cooling engine—setting a new standard for both performance and style. With acrylic or acetal tops, a durable nickel-plated copper cold plate, and a fully integrated D-RGB lighting system, these blocks will elevate any high-end build.
EK-Matrix7 Support – Perfect Loop Planning
The EK-Quantum Vector³ follows EK-Matrix7, a standard that simplifies liquid cooling assembly by aligning ports and component spacing for intuitive tube routing, offering:
- Seamless integration with EK-Quantum Reflection² distribution plates
- Straightforward tube bending & loop planning – less time spent measuring and adjusting
- Hassle-free vertical & horizontal GPU mounting – a clean, professional look with minimal effort
Whether mounting the GPU vertically or horizontally, Matrix7 ensures a precise, frustration-free build.
Pre-Orders Coming Soon!
The EK-Quantum Vector³ water blocks for RTX 50 Series GPUs will soon be available for order on our shop and through our trusted resellers and partners, with an official release to follow. Stay tuned for detailed specifications and availability updates.Â
Prepare for the future of cooling—your RTX 50 Series GPU deserves the best.
