Thermaltake Delivers Peak Cooling Power for Gaming and Workstation Laptops with the Massive EXTREME, a High-Performance Notebook Cooler with Powerful Cross-Flow Fan and Sealed-Chamber Design
Image: Thermaltake
(PR) Thermaltake, a leading PC DIY brand for premium hardware solutions, is thrilled to launch the Massive EXTREME, a high-performance notebook cooler designed to deliver exceptional cooling for gaming and workstation laptops. With a cross-flow fan with an impressive 3500 RPM fan speed and sealed chamber design, it ensures superior temperature control even during demanding tasks.
Massive EXTREME is Thermaltake’s first laptop cooler equipped with a powerful cross-flow fan, its vortex airflow design offers smoother air circulation to enhance the cooling capacity. This 120mm PWM fan delivers up to 48.5 CFM airflow and 29.5 mm-H2O static pressure while keeping a noise level of 55.0 dB-A. Furthermore, the included high-density memory foam forms a sealed chamber, concentrating cooling on critical hotspots and significantly lower laptop temperatures.
The built-in temperature sensor allows users to monitor laptop conditions easily. The temperature is shown on the digital panel and can be toggled between Celsius and Fahrenheit. Based on the real-time information, you can freely adjust the Massive EXTREME from 800 to 3500 RPM via its Scroll Wheel Fan-Speed Control, achieving an ideal balance between fan speed and noise level.
The Massive EXTREME also offers customized functions to fit your usage habits and style. It features the 2-stage base risers and the two hidden risers, enabling height and angle adjustment for a more ergonomic typing position. Moreover, the Massive EXTREME supports three additional USB 2.0 ports and one USB 3.2 (Gen 2) Type-C port with quick charge and high-speed data transfer for laptops, effortlessly connecting peripherals such as keyboards, mice, etc. To enhance visual appeal, the Massive EXTREME offers 256-color RGB spectrum lighting and five lighting modes, allowing you to personalize it to match your aesthetics.
The maintenance of the Massive EXTREME is easy as well. It includes a bottom filter to prevent dust buildup, and the removable and washable design enables cleaning it easily with water and reattaching it for continuous use. In addition, the Massive EXTREME has a universal power adapter, and its interchangeable plugs in the US, EU, UK, and AU standards allow you to seamlessly cool down your high-performance laptop without the limit of regions.
Experience premium cooling with the Massive EXTREME and unleash the full potential of your high-end gaming and workstation laptops. With powerful airflow, customizable design, and expanded connectivity, it keeps notebooks at optimal performance no matter how intense the task might be.
Massive EXTREME Gallery
Features of the Massive EXTREME
Optimized Airflow with Cross-Flow Fan Design
The Massive EXTREME is engineered for high-performance notebook cooling, featuring a strong 120mm cross-flow fan. With a vortex airflow design, it ensures smooth and efficient air circulation for superior cooling.
Extreme Cooling Capability
The 120mm cross-flow fan delivers up to 48.5 CFM airflow, 29.5 mm-H2O static pressure, and operates at a noise level of 55.0 dB-A. Its PWM control allows speeds up to 3500 RPM for adaptable cooling performance.
Superior Cooling with Sealed Chamber
The Massive EXTREME notebook cooler includes a high-density memory foam, creating a sealed chamber that concentrates active cooling performance on the critical hotspot, significantly reducing laptop’s temperature.
Smart Temperature Sensor
Massive EXTREME features a built-in temperature sensor that monitors the temperature. The reading is displayed on the digital panel, allowing you to easily track your laptop’s condition and adjust the notebook cooler’s fan speed as needed.
Looking to achieve the perfect balance between fan speed and noise level for any situation? The fan control lets you freely adjust speeds from 800 to 3500 RPM. Simply scroll up to increase speed or down to decrease it, giving you precise control with ease.
Full Control, Ultimate Personalization
The digital panel displays the temperature from the built-in sensor and the current fan speed.
Below the panel, there are 4 buttons:
  • Power: Turn the power on/off.
  • °C/°F: Toggle the temperature display between Celsius and Fahrenheit.
  • Mode: Adjust the lighting mode.
  • Color: Adjust the lighting color.
Dynamic RGB Lighting in Style
Massive EXTREME has 5 different lighting modes (RGB Spectrum, RGB Gradient, Breathing, Blink, and Static) that can show a stunning 256-color RGB spectrum. Customize the lighting to suit your aesthetics!
Flexible Height & Angle Adjustment
The Massive EXTREME is designed with 2-stage base risers offering three adjustable height settings, along with two hidden risers near the cross-flow fan for extra elevation. These adjustments ensure a comfortable typing position and enhance your usage experience.
Multi-Functional I/O Ports
The back of the notebook cooler is equipped with multiple I/O ports, offering expanded connectivity options. Once connected to your laptop, the Massive EXTREME provides three additional USB 2.0 ports and one USB 3.2 (Gen 2) Type-C port with quick charge and high-speed data transfer. This allows for seamless integration of peripherals such as keyboards, mice, and other devices.
Removable and Washable Bottom Filter
The bottom filter effectively protects the Massive EXTREME from dust buildup. It’s both removable and washable, making cleaning simple. Just rinse, dry, and reattach for continuous use.
Universal Power Adapter
The Massive EXTREME comes with a power adapter including the interchangeable plugs in the US, EU, UK, and AU standards.
