(PR) GAMDIAS Technology, a leading brand in high-performance PC gaming hardware, is excited to unveil the new CHIONE P5 Series LCD display liquid cooler, as part of GAMDIAS’s 2025 vision, embodied by the annual slogan “GAMING REIMAGINED.” Available in sleek black and white color options, it comes in two sizes: 240mm and 360mm. This cutting-edge cooler delivers exceptional CPU cooling, featuring a 3.4” customizable IPS LCD display, a high-performance PWM pump with speeds up to 2600 RPM, and ARGB PWM NOTUS fans. “The CHIONE P5 embodies our values and beliefs: through the combination of high-end technologies and the aesthetic design, GAMDIAS enables gamers at all levels to perform at their best,” said Stimson Wang, CEO of GAMDIAS, making it the ultimate cooling solution for gamers and enthusiasts.
PERSONALIZED LCD DISPLAY
The CHIONE P5 Series features a brilliant 3.4-inch IPS LCD display with a high resolution of 480×480, allowing you to monitor real-time system performance statistics while offering full personalization by setting custom images or animated GIFs as the background. Below the LCD display, an ARGB lighting strip adds a vibrant glow, enhancing your system’s aesthetics with dynamic lighting effects.
FULLY CUSTOMIZABLE SOFTWARE
The CHIONE P5 Series is equipped with ZEUS CAST software, offering real-time monitoring of essential system information once connected to the motherboard via the 9-pin USB header. This versatile software allows users to upload custom images or animations, adjust screen orientation and brightness, and display a range of system information. It offers multiple display modes, including options to show 1, 2, or 3 system stats, clock and calendar modes, gallery mode, and note mode, providing a comprehensive and customizable experience for users seeking both functionality and aesthetics.
EXTREME PERFORMANCE PUMP
The CHIONE P5 Series features an upgraded coldplate with 0.12mm microflow channels, designed to enhance heat dissipation by targeting CPU hotspots and maximizing thermal transfer. Its optimized fluid routing system and 12-slot 10-pole motor ensure stable pump speeds of up to 2700 RPM, delivering strong, quiet circulation that keeps the copper base cool. The series also includes a magnetic rotatable LCD display, which can be effortlessly adjusted by simply pulling and reattaching it, providing customizable orientation for added convenience and flexibility.
ADVANCED COOLING AND STREAMLINED CABLE MANAGEMENT
The radiator features GAMDIAS’s innovative NOTUS fans, designed for superior airflow performance with high static pressure of up to 81.81 CFM and fully addressable ARGB lighting for a sleek, modern aesthetic. Operating silently at 25.48 dBA at 1600 RPM and peaking at only 34.91 dBA at 2200 RPM, the fans ensure a quiet environment while maintaining exceptional efficiency. The closed-loop system ensures stable RPM, even under load or when mounted on the radiator, delivering consistent performance and longevity. Additionally, the hidden cable routing mechanism ensures a clean and organized build, offering a professional and streamlined setup.
UNIVERSAL COMPATIBILITY
The CHIIONE P5 Series AIO cooler includes an upgraded mounting kit for seamless installation on both AMD and Intel platforms, including the newest Intel LGA 1851 and AMD AM5.
KEY FEATURES FOR CHIONE P5 Series
- 3.4” IPS LCD Screen
- 480 x 480 Resolution
- Customize LCD Background
- Rotatable Magnetic Display
- Optimized Copper Base for Better CPU Contact
- Hidden Cable Routing Mechanism
- Hydraulic Bearing PWM Fans
- ZEUS CAST Software
- ARGB Motherboard Sync
- Supports LGA 1851 / AM5
MSRP (USD) for the CHIONE P5 Series
- CHIONE P5-360: 159.90
- CHIONE P5-360 WH: 164.90
- CHIONE P5-240: 139.90
- CHIONE P5-240 WH: 144.90
About GAMDIAS Technology
Founded in 2012, GAMDIAS has become a leader in quality and innovation for gaming components and peripherals. We focus on creating high-performance, cutting-edge products that exceed the expectations of gamers, PC enthusiasts, and virtual influencers alike. Our commitment to detail ensures an unparalleled gaming experience. Operating in six major markets and supported by a network of 60 regional distributors, we are dedicated to providing top-tier products for gamers of all levels.
