FSP MEGA TI PSU Series Features Dual 12V-2×6 Power Connectors and Is Certified with 80 PLUS Titanium and Cybenetics Titanium Ratings
Image: FSP
The FSP MEGA TI PSU series is designed for PC users needing efficient power delivery, quiet operation, and a wide range of connectivity options. With ATX 3.1/PCIe 5.1 compliance they offer options for the latest graphics cards and feature dual 12V-2×6 power connectors for gaming use as well as content creation/AI development usage scenarios. The FSP MEGA TI series will be available in 1350-watt ($399) or 1650-watt ($459) models. Both measure 180 x 150 x 86mm which allows additional options for those working with smaller PC cases.
Press Release (via Official Website):
Superior Performance and Maximum Efficiency
The MEGA TI series is built for uncompromising performance, featuring Interleaved PFC topology and high-performance MOSFETs and SiC diodes from Infineon for exceptional power regulation. With FSP’s proprietary Micro Tolerance Load Control (MTLC®) technology, voltage regulation is maintained at an ultra-precise ±0.5%, surpassing Intel’s ATX 3.1 standards. Certified with 80 PLUS® Titanium and Cybenetics® Titanium ratings, these PSUs ensure minimal power loss, lower heat output, and near-silent operation, making them an optimal choice for high-performance systems.
Dual Native PCIe 12V-2×6 Power Connectors
Designed for the latest NVIDIA and AMD graphics cards, the MEGA TI series features two PCIe 12V-2×6 connectors along with additional 8-pin options for superior flexibility. The fully modular design not only simplifies installation but also enhances airflow for improved cooling. Embossed cables contribute to a sleek, clutter-free build, combining aesthetics with functionality for high-end PC setups.
Whisper-Quiet Cooling with Zero RPM Mode
Equipped with an advanced cooling system, the MEGA TI series incorporates an eco semi-fanless switch and a 135mm fluid dynamic bearing fan to ensure silent operation while maximizing durability. The Zero RPM mode keeps the fan off under low to moderate loads for an ultra-quiet experience. Additionally, the 1650W model holds a Cybenetics LAMBDA 230V A++ certification, offering best-in-class acoustic performance.
Unmatched Durability and Safety
Built to withstand harsh conditions, the MEGA TI series features an exclusive conformal coating that protects against dust and moisture, making it reliable in environments with up to 95% relative humidity. High-quality 105°C Japanese electrolytic capacitors ensure long-term stability, while a full suite of protective mechanisms—including OCP, OVP, SCP, OPP, UVP, OTP—safeguard components from electrical hazards.
Compact Yet Powerful Design
Despite its formidable power, the MEGA TI series maintains a compact form factor at just 180 x 150 x 86mm, making it ideal for space-conscious builds without compromising performance.
Pricing and Availability
The FSP MEGA TI 1350W and 1650W PSUs are now available through authorized FSP retailers and the FSP online store. The MSRP (excluding tax) is set at:
  • MEGA TI 1650W: US$459
  • MEGA TI 1350W: US$399
For more product information, please visit the FSP official website.
