(PR) ENDORFY expands its product line with the introduction of modern, modular power supply units compliant with ATX 3.1 and PCIe 5.1; ENDORFY Supremo FM6 1000 W and ENDORFY Supremo FM6 850 W. New ENDORFY’s power supplies are a great choice for powering even the most efficient PCs and also ensure readiness for future hardware upgrades. This is a solution that will work well in both gaming computers and professional environments. Both power supplies come with a 10-year manufacturer’s warranty.
MODERN ATX 3.1 PSUS WITH PCIE 5.1 SUPPORT
Both power supply models are designed according to ATX 3.1 guidelines, which means even better performance, stability and resistance to momentary power surges, compared to previous generations. The included 12V-2×6 cable ensures full compatibility with cards powered according to PCIe 5.1, allowing even the latest GPUs to work without the need for adapters. Of course, for classic solutions, PCI-E 8-PIN cables are also included. All cables in the ENDORFY Supremo FM6 1000 W and ENDORFY Supremo FM6 850 W power supplies are fully modular.
HIGH ENERGY EFFICIENCY AND ALL-JAPANESE CAPACITORS
The ENDORFY Supremo FM6 1000 W and ENDORFY Supremo FM6 850 W are characterized by high energy efficiency, as confirmed by the 80 PLUS® Gold certification. The power supplies operate quietly and do not get excessively hot, even under load, resulting in an extended service life. What’s more, both models use only premium Japanese capacitors, which retain their operating parameters even at high temperatures (105 °C), so they will work consistently even when used in very demanding conditions.
QUIET OPERATIONS WITH RELIABLE FLUCTUS FAN
ENDORFY power supplies are characterized by near-silent operation. This is achieved thanks to the Fluctus 120 mm fan, optimized for the best possible airflow and efficiency. This is an extremely quiet solution with an FDB bearing as well as fan blades designed for reliable operation and psychoacoustic optimization. It not only makes the noise generated during fan operation less audible, but also more pleasant for the human ear.
TROUBLE-FREE OPERATION CONFIRMED BY A LONG WARRANTY
The new ENDORFY units are a designed for reliability and safety at the highest level, even when used in the most demanding environments. They have been equipped with a full package of electrical and thermal security measures that protect the computer from voltage spikes, short circuits, overloads and overheating. The high quality and trouble-free operation of the ENDORFY Supremo FM6 1000 W and ENDORFY Supremo FM6 850 W is confirmed by a long 10-year warranty.
FUTURE-PROOF AND RELIABLE SOLUTION FOR THE MOST DEMANDING USERS
The ENDORFY Supremo FM6 1000 W and ENDORFY Supremo FM6 850 W power supplies are state-of-the-art units ready for the latest graphics cards and compliant with ATX 3.1 and PCIe 5.1 standards, providing high performance and stability even in the most demanding setups. Thanks to their refined design, high energy efficiency confirmed by 80 PLUS® Gold certification, Japanese capacitors and Fluctus 120 mm fan, the power supplies offer almost silent operation and low temperatures. Their 10-year warranty is an additional confirmation of durability and reliability.
AVAILABILITY
Both the ENDORFY Supremo FM6 1000 W and Supremo FM6 850 W are available as of today. Product images and data sheets can be downloaded from the following product pages:
About ENDORFY
ENDORFY can cater to every desire and requirement. All you need is your imagination and passion for computer hardware. We handle the rest and deliver proven, functional and efficient products. This combination will make you proud and let you experience the emotions that come with computer hardware, its configuration and PC gaming.
