Control: Ultimate Edition Adds HDR Support, Ultra Ray Tracing Preset, FOV Slider, NVIDIA DLSS 3.7, and More
Image: Remedy Entertainment
Remedy Entertainment has rolled out Update 1.30, a surprise update for Control: Ultimate Edition that delivers several new features for the PC version of the 2019 action-adventure game, including HDR and widescreen monitor support, a new Ultra ray tracing preset, an FOV scaling setting, NVIDIA DLSS updates (i.e., DLAA and DLSS 3.7), and much more.
See below for the patch notes, which also note the unlocking of three outfits for all players: the Astral Dive Suit, Tactical Response Gear, and Urban Response Gear, all of which were pre-order exclusives.
March 2025 Update (1.30) Release Notes (PC)
OUTFITS
The following outfits are now available to all players. The outfits can be accessed and equipped from the Control Point in the Central Executive Sector area.
• Astral Dive Suit (formerly a pre-order exclusive)
• Tactical Response Gear (formerly a pre-order exclusive)
• Urban Response Gear (formerly a pre-order exclusive)
MISSIONS
All players will receive the mission Dr. Yoshimi Tokui’s Guided Imagery Experience, featuring voiceover by Hideo Kojima. The mission is playable when you pick up the Dr Tokui Tapes collectible in the Extrasensory Lab of the Research Sector. (This mission was previously exclusive to the PlayStation 4 Digital Deluxe version of Control.)
GRAPHICS
• Added HDR support
• Added new Ultra ray tracing preset, which gets you more rays per pixel and higher temporal stability
• Added ultrawide monitor support for up to 48:9 monitors
• Added an FOV scaling setting for the gameplay camera
• Updated SDR to 10bit (from 8bit), which reduces visible color banding
• Improved graphics adapter detection at startup, with automatic selection between DX11 and DX12
• Implemented screen aspect ratio fixes for ultrawide monitors
• Your current monitor resolution can now reliably be selected from the screen resolution and rendering resolution menus
• Added rendering resolution support beyond 4K
• Implemented texture streaming fixes
• Ray tracing bug fixes
DLSS SUPPORT
• Added DLSS support for arbitrary resolutions
• Added DLAA support
• Updated DLSS to DLSS 3.7, with higher temporal stability
• Film grain added back to DLSS SR
• Fixed shadow resolution when DLSS is enabled
• Added resolution dependent mip map bias for DLSS. This enhances texture quality, for example when applying the DLSS Performance setting.
GENERAL
• Updated the audio on cinematics and end credits to remove unintended channel mixing. You will no longer hear anything that isn’t intended to be heard. (It wasn’t the Hiss, it was us. Sorry.)
• Several bug and crash fixes
“We’re happy to announce that all owners of Control Ultimate Edition will be receiving a free content update. The update is hitting PC players (Steam and Epic Games Store, GOG to follow later) today, including several improvements to support newer hardware,” Vida Starcevic (Senior Community Manager at Remedy Entertainment) told players today.
“In the near future we will release this same update for PlayStation 5 and Xbox Series X|S platforms. We have a small team working on these updates so we want to space them out to give us time to fix potential issues that might come up. We appreciate your patience!”
