Some of SAPPHIRE’s AMD Radeon RX 9070 Series Graphics Cards Come with Cushioning Material That May Affect Cooling Capacity or Result in Product Failure If Not Removed, Distributor Warns
Image: ASK Corporation
The PURE Radeon RX 9070, PURE Radeon RX 9070 XT, and PULSE Radeon RX 9070 XT are shipped with cushioning material that may “result in a decrease in cooling capacity or product failure” if it isn’t removed, according to a new warning to customers that ASK Corporation, an authorized distributor of graphics boards for SAPPHIRE Technology, published on its support site today.
From an ask-corp.jp support page, which includes a table of the affected GPUs and the relevant part, which some users may apparently fail to spot before installation:
Product NameSAPPHIRE PURE Radeon RX 9070 XT GAMING OC 16GB GDDR6SAPPHIRE PULSE Radeon RX 9070 XT GAMING 16GB GDDR6SAPPHIRE PURE Radeon RX 9070 GAMING OC 16GB GDDR6
Model numberPURERX9070XT16GB/
11348-02-20G
PULSERX9070XT16GB/
11348-03-20G
PURERX907016GB/
11349-02-20G
JAN code489510629589648951062959194895106295957
Ask CodeVD8984VD8985VD8987
We are an authorized distributor of Sapphire Technology’s AMD Radeon RX 9070 XT and RX 9070 graphics boards. We would like to inform you that the protective cushioning material (sponge) that is attached to the product at the time of shipment must be removed before using the product.
There is protective cushioning material sandwiched in the heat sink part on the back of the product, so please remove it from the red frame part in the image or by pushing it in the direction of the arrow. Please be careful not to try to cut it with a cutter or screwdriver, as this may damage the product.
If you are unable to remove it, peel off the sticker on top and remove it through the gap made by removing the screw in yellow in the image.
