Thermaltake Updates Its CT EX ARGB Sync PC Cooling Fan Series with Four New “Edgy” Color Options: Racing Green, Gravel Sand, Bumblebee, and Pink
Image: Thermaltake
(PR) Thermaltake, a leading PC DIY brand for premium hardware solutions, is thrilled to introduce the new-colored additions to the CT EX ARGB Sync PC Cooling Fan and CT EX Reverse ARGB Sync PC Cooling Fan in Racing Green, Gravel Sand, Bumblebee, and Pink. Thermaltake continues to merge style and technology, offering bold and edgy color options that allow users to personalize their setups.
The CT EX ARGB Sync PC Cooling Fan series is now available in eight colors: Black, White, Matcha Green, Hydrangea Blue, Racing Green, Gravel Sand, Bumblebee, and Pink. Furthermore, it includes 120/140mm sizes in both standard and reversed blade versions. With these diverse selections, PC builders can effortlessly create unique aesthetics that perfectly complement Thermaltake’s chassis lineup.
The CT EX ARGB Sync PC Cooling Fan, now upgraded with MagForce 2.0, offers a superior magnetic connection for effortless installation. Its innovative design eliminates excess cables, ensuring better cable management and a cleaner, more organized chassis interior.
The CT120 EX delivers 68 CFM airflow and 2.95 mm-Hâ‚‚O static pressure, while the CT140 EX offers 90.3 CFM airflow and 3.07 mm-Hâ‚‚O static pressure, all with low noise levels for enhanced cooling performance. Additionally, the CT EX series comes in both standard and reverse blade options, giving users the flexibility to optimize airflow direction for their setup.
Designed for both chassis and radiators, the CT EX features a durable frame and anti-vibration rubber pads, minimizing noise and ensuring stable operation. Its 9 addressable LEDs support 16.8 million color customizations via 5V motherboard lighting software, with no extra controllers required.
With the addition of Racing Green, Gravel Sand, Bumblebee, and Pink, the CT EX ARGB Sync PC Cooling Fan series now offers more customization options than ever. Equipped with Thermaltake’s new MagForce 2.0 design, it’s the perfect blend of style and functionality for any setup.
Features of the CT120/140 EX ARGB Sync PC Cooling Fan (3-Fan Pack)
Steady Connection with MagForce 2.0
Evolved from SWAFAN EX’s Magnetic Force Design, the new MagForce 2.0 has the Pogo pin contact pads that are TWO times larger for greater tolerance. This enhancement significantly reduces the potential faulty alignment no matter if you are daisy-chaining fans together or connecting fans with cable, further boosting the installation efficiency and streamlining the building experience.
Say Goodbye to Excessive Cables
Connect your fans with CT EX’s MagForce 2.0 Quick Connect Design and be free from messy cables.
Remarkably Improved Performance
After extensive research and testing, the CT120 EX ARGB Sync can generate 68 CFM of airflow and 2.95 mm-H2O static pressure while maintaining a 28.5 dBA noise level; the CT140 EX ARGB Sync can generate 90.3 CFM of airflow and 3.07 mm-H2O static pressure while maintaining a 30.7 dBA noise level, pushing ARGB fans to their limits.
The CT120/140 EX Reverse ARGB Sync is capable of providing superb cooling performance while running at full speed. It can generate a 65.82 / 94.95 CFM airflow and 1.87 / 2.54 mm-H2O static pressure under a 31.2 / 32.8 dBA noise level. With this huge improvement, the CT120/140 EX Reverse ARGB Sync has now become the top-performing ARGB fan in our latest fan lineup with a thickness of 25mm.
Solid Structure for Better Performance
The new CT Series fan frames are crafted to be steady and robust so the fan won’t deform easily. We have also modified the exterior design to allow the fans to fit the chassis or radiator even better, so there won’t be gaps for air to slip through.
A little Surprise for Extra Security
CT Series Fans are equipped with four round undetachable anti-vibration rubber pads on each of the fan’s corners. They are designed to be stable and dampen the fan’s vibration, allowing the fans to spin at a higher speed under certain noise levels.
Spectacular Lighting Effects
Featuring 9 addressable LEDs for users to build up spectacular lighting effects through motherboard sync software, providing great coverage of 16.8 million uniform colors. You can create stunning lighting effects through your motherboard software to customize your ideal lighting effects. The CT Series ARGB Fans now support ASUS, MSI, GIGABYTE, BIOSTAR, and ASROCK sync software.
CT EX Reverse ARGB Sync: Unlocks the Full Potential of RGB Lighting
Reversed blade fan enables airflow from rear to front while fully showing lighting effects. No more sacrificing aesthetics for your airflow direction.
Note: This product requires motherboard sync for ARGB lighting effects
Sync with Motherboard RGB Software
Designed to synchronize with ASUS Aura Sync, GIGABYTE RGB Fusion, MSI Mystic Light Sync, and ASRock Polychrome. It supports motherboards with a 5V addressable RGB header, allowing you to control the lights directly from the software mentioned above without installing any extra lighting software or controllers. For more details, please visit ASUS, GIGABYTE, MSI, and ASRock official websites.
Product Links
CT120 EX+CT120 EX Reverse:
https://www.thermaltake.com/catalogsearch/result/?q=CT120+EX
CT140 EX+CT140 EX Reverse:
https://www.thermaltake.com/catalogsearch/result/?q=CT140+EX
Where to Buy
TT USA
TT China
TT Germany
TT Taiwan
TT Australia
