Give Your Processor and Nearby Components a Blast of Coolness with the Phanteks Glacier One 420 D30 X2 AIO, Featuring an Integrated Pump Fan for VRM, SSDs, and Ram
Image: Phanteks
Already available in a 360mm configuration, Phanteks is upping its D30 X2 AIO cooling capacity with a 420mm model. For those seeking the best CPU AIO cooling solutions, there are already a lot of details to research. From radiator sizes, RPMs, noise, to pump designs, and more, PC enthusiasts with a processing beast may have much to consider. Factor in the heat given off from modern fast Gen5 NVMe drives, DDR5 memory, and VRMs supplying power to everything connected to the motherboard, and then you’ve got even more to consider for maintaining high performance and longevity of components. Well, Phanteks has you covered with its D30 X2 AIO line by including an integrated fan to help cool all of the above, and if a 360mm AIO isn’t enough, then the Glacier One 420 D30 X2 ought to be enough to sink those titanic temps.
Designed with maximum clearance in mind, the Glacier One D30 X2 fits seamlessly into a wide range of builds, while the brushed aluminum
pump cover with an integrated fan adds active cooling to nearby VRMs and M.2 SSDs – enhancing stability and overall system performance.
-Phanteks
Phanteks has said the Glacier One 420 D30 X2 will be available next month. Pricing for either black or white versions is the same: $189.99 – €189.90 – £169.90, so there’s no worry about being charged extra over a color preference. The D30 X2 line also supports DRGB for those looking to further personalize their builds.
Key Features (via Press Release):
  • Advanced AIO liquid cooler for high-end gaming and workstation builds
  • Part of the NEXLINQ ecosystem for smarter, more streamlined builds
  • Interconnecting D30 fans for easier cable management
  • Efficient copper base and fin array for top-tier thermal performance
  • Compact design ensures compatibility with RAM and motherboard components
  • Sleek Evolv X2-inspired aluminum cover with integrated VRM/M.2 fan
  • Supports Intel LGA 1700/1200/115x and AMD AM4/AM5 sockets
Presumably (but no guarantees), the Glacier One 420 D30 X2 will feature similar specifications to the 360mm version. That model is currently available, also in black or white, for: $179.99 – €179.90 – £159.90.
Glacier One 360 D30 X2 Specifications:
  • Model No.: PH-GO360D30_DBK02
  • Materials: Aluminum | ABS plastic | Copper
  • Intel Compatibility: LGA 115x | 1200 | 1700 | 1851
  • AMD Compatibility: AM4 | AM5
  • Radiator Dimensions: Length (397mm) x Width (120mm) x Height (27mm)
  • Pump Dimensions: Length (85.5mm) x Width (80.9mm) x Height (65.9mm)
  • Pump Details
    • Motor Speed: 3100 RPM ± 10% (100% Duty Cycle)
    • Power: 12V | 0.28A – 0.45A | 3.36W – 3.96W
    • Pump DC Cable: 400 + 10 mm | 15.74 + 0.39 in
    • Sound Level: 20.0 dBA
    • Material: Copper | ABS | Aluminium rim
    • D-RGB Connector: Linq6
    • D-RGB Cable Length: 470 + 105 ± 10 mm | 18.50 + 4.13 ± 0.39 in
  • Tube Details
    • Length:400 mm | 15.74 in
    • Diameter:12.5 mm ⌀| 0.49 in ⌀
    • Tube Clips: 3x
    • Material: CIIR rubber| Braided sleeves
  • FANS
    • Fan Model:D30-120 D-RGB
    • Dimensions: Length (120mm) x Width (120mm) x Height (30mm)
    • Speed: 250 – 2000 ± 10% RPM
    • Air Flow: 72.72 CFM
    • Fan Static Pressure: 3.01 mm H₂O
    • Sound Level: 35.13 dBA
    • MTFB: 150.000 Hours
    • Connector: 4-Pin PWM
    • Cable Length: 700 mm | 27.55 in Daisy-chain
