GIGABYTE AORUS GeForce RTX 5080 MASTER 16G Video Card Review
Test Setup
We are using an AMD Ryzen 7 9800X3D for testing, and for 2025, we have upgraded our testing PC with completely updated components from top to bottom. We are using the motherboard’s current default BIOS settings on the latest release BIOS. We have enabled PCI-Express Resizable BAR in the motherboard BIOS. We have enabled EXPO I in the BIOS for the memory. We are using a fresh install of Windows 11 Pro with the latest Windows Updates, including the 24H2 update. We have the latest drivers installed, including the latest chipset drivers.  We are using the “Balanced” power profile in Windows Settings,and Core Isolation/Memory Integrity (VBS) is Enabled.
The FPS Review Score
This review is evaluating the GIGABYTE AORUS GeForce RTX 5080 MASTER 16G Video Card video card. This card represents the flagship card in the GIGABYTE lineup for the RTX 5080 category. The build quality and attention to detail is obvious. The cooling functions superbly. There is just enough RGB and an added LCD screen makles a nice touch. The overclocking ability of this card is very good. Overall game performance is lackluster and does take away from an otherwise excellent video card. Pricing is a bit lofty for the performance and is a consideration as well.
