MSI Project Zero: MSI B850 GAMING PLUS WiFi PZ Motherboard Review & Intro to MAG PANO 100R PZ Gaming Case
UEFI/BIOS
The MSI B850 GAMING PLUS WiFi PZ uses the “Click X” BIOS. This is an AMI BIOS that is designed for ease of navigation and very simple, straightforward menu organization. On initial boot, you are greeted by the “Performance” screen, essentially asking if you wish to enable Precision Boost Overdrive. You are then taken to the EZ Mode screen, which has almost everything you need. The Advanced Mode screen is organized to allow one to set CPU and Memory overclocking as well as all the motherboard I/O options. The Click X BIOS is one-click oriented, with very responsive navigation.
On the EZ Mode screen, you will see an option labeled “X3D Gaming Mode”. This is AI – BIOS-controlled software directed specifically at X3D processors, touted to enhance gaming FPS “under certain conditions” by up to 10%. We will fully evaluate this mode in an upcoming MSI Project Zero motherboard review, so stay tuned.
Our MSI B850 GAMING PLUS WiFi PZ arrived with BIOS version E7E75.AMSI.1A10 dated 29 May 25. We updated the BIOS to version E7E75.AMSI.1A25 dated 10 SEP 25. We used the M-Flash BIOS utility, which we have discussed in other MSI reviews. This utility uses an unzipped BIOS version on a flash drive. Once you identify the correct file, the utility does all the work. MSI also offers “Flash-BIOS” from the rear I/O panel, which needs only a flash drive and a PSU.
All in all, the MSI Click X BIOS is very simple to use, well-organized and has reasonably good explanations of functions when they are highlighted. On the motherboard’s webpage, under support, you may also download a very detailed BIOS guide, which is quite complete.
The FPS Score
We reviewed the MSI B850 GAMING PLUS WiFi PZ motherboard. This is a new "Back-Connect" concept built to reduce visible cable clutter in modern PC cases. The motherboard delivered on this concept as well as performing identically to other B850 boards we have reviewed. The impressive aspect is the ease of assembly and clean, well organized look of the build. This is an excellent design and well worth consideration if building a new PC.
