LIAN LI Launches SP and SX Platinum SFX Series PSUs with 80 PLUS Platinum Certification
Image: Lian Li
Lian Li has released its SP (850W/1000W) aimed at SFX builds, and SX (850W/1000W/1200W) Platinum series in black or white. Power supplies rarely get the attention they deserve with many a PC enthusiast focused more on the FPS a CPU or GPU provides or perhaps more exciting visuals rendered by said GPU but without a solid PSU neither may function properly and you never know if you’ll end up on Reddit as another user reporting another failure so it’s worth doing the homework for the right PSU.
The SP Platinum series might just be the right fit for someone, either doing a small form factor build or even an mATX project where a little more free space can make a difference for other challenges in getting everything into place.
“LIAN LI, a leading manufacturer of computer chassis and accessories, announces the SP Platinum Series, fully modular 850W and 1000W SFX power supplies engineered for high-end small-form-factor builds. Delivering 80 PLUS® Platinum certified efficiency, the SP Platinum meets Intel ATX 3.1 and PCIe 5.1 requirements and integrates LIAN LI’s in-house designed 12V-2×6 for reliable modern GPU power delivery.”
-Lian Li
Those doing a more traditional ATX build might appreciate the 1200W model for a more power-hungry system or perhaps are just looking for a solid PSU to get the job done.
“LIAN LI, a leading manufacturer of computer chassis and accessories, announces the launch of the SX Series PSU, available in 850W, 1000W, and 1200W with 80 PLUS® Platinum certification for up to 92% efficiency. Built to deliver stable, future-ready power, the SX Series is fully compliant with Intel’s ATX 3.1 specification and features a native PCIe Gen 5.1 12V-2×6 connector capable of supplying up to 600W directly to next-generation GPUs.”
-Lian Li
Lian Li SP Platinum Series
Both the 850W and 1000W models have an 80 PLUS Platinum certification, meaning users can expect optimum performance under load and, combined with premium Japanese capacitors and protections, are ready to take on heavy tasks. They support ATX 3.1 and PCIe 5.1 and include a braided 12V-2×6 cable for modern GPUs. The official product page featuring complete specifications can be found here.
  • Fully modular 850W and 1000W models SFX-sized PSUs with 80 PLUS® Platinum certified efficiency
  • Includes extension power cord with an inline on/off switch for external power control
  • Fully compliant with Intel ATX 3.1 / PCIe 5.1 and equipped with LIAN LI’s in-house designed 12V-2×6 solution for modern GPUs
  • Smart cooling 92mm FDB fan with silent fanless operation at ≤40% load
  • Super-flexible braided-texture modular DC cables for easier routing in tight SFF builds
  • Built with premium 100% Japanese 105°C rated capacitors and a full protection suite (OCP/OVP/OTP/OPP/SCP/UVP/NLP/SIP)
  • SFX-to-ATX bracket included for seamless use in standard ATX cases
850W Black: https://www.newegg.com/p/pl?d=9SIAFSTKK39361
850W White: https://www.newegg.com/p/pl?d=9SIAFSTKK39363
1000W Black: https://www.newegg.com/p/pl?d=9SIAFSTKK39364
1000W White: https://www.newegg.com/p/pl?d=9SIAFSTKK39362
Lian Li SX Platinum Series
Image: Lian Li
Aimed at more conventional ATX builds, the SX series is available in 850W, 1000W, and 1200W models. They come with a 10-year warranty and also support ATX 3.1 and PCIe Gen 5.1 specifications. According to Lian Li MSRP ranges from $119.99 for the 850W version up to $159.99 for the 1200W model. Complete specifications can be found on the official product page here.
MSRP
SX0850P$119.99
SX1000P$149.99
SX1200P$159.99
Table: Lian Li
  • Compact 140 mm ATX power supply with 80 PLUS® Platinum efficiency
  • Up to 5 x PCIe cables (1000W/1200W models), including 2 x ATX 3.1 native PCIe Gen 5.1 12V-2×6 to PCIe 6+2pin cables
  • 120mm FDB fan with Zero RPM mode via on/off switch
  • Premium build with 100% Japanese 105°C capacitors
  • High-amperage single +12V rail for stable and consistent power
  • Black or white color options with an embossed mesh design and flexible braided-texture modular cable
  • Available in 850W, 1000W, and 1200W
  • Covered by a 10-year warranty
Newegg
850W Black: https://www.newegg.com/p/pl?d=9SIAFSTKKB5227
850W White: https://www.newegg.com/p/pl?d=9SIAFSTKKB5228
1000W Black: https://www.newegg.com/p/pl?d=9SIAFSTKKB5229
1000W White: https://www.newegg.com/p/pl?d=9SIAFSTKKB5230
1200W Black: https://www.newegg.com/p/pl?d=9SIAFSTKKB5231
1200W White: https://www.newegg.com/p/pl?d=9SIAFSTKKB5232
Amazon
850W Black: https://www.amazon.com/dp/B0FPCGCFLD
850W White: https://www.amazon.com/dp/B0FPCG8CJM
1000W Black: https://www.amazon.com/dp/B0FPCF4H5W
1000W White: https://www.amazon.com/dp/B0FPCDJYBW
1200W Black: https://www.amazon.com/dp/B0FPCFQ8TP
1200W White: https://www.amazon.com/dp/B0FPCH3SY1
