In this review, we have taken two GeForce RTX 5060 Ti video cards, one with 16GB of GDDR7 and the other with 8GB of GDDR7, and compared performance across thirteen games.
With the launch of the GeForce RTX 5060 Ti in 2025, NVIDIA provided two distinct variants utilizing the same GPU and specifications, clock speeds, and memory bus, but have configured the VRAM capacity differently. While both operate on the same 128-bit memory bus, and GDDR7 at 28Gbps for 448GB/s of memory bandwidth, there is a distinct 16GB VRAM capacity version and a distinct 8GB VRAM capacity version. Both of these options utilize the same Blackwell GB206 die, and share the same core count, ROP, and TMU count, Tensor Core, and RT core count. Both video cards share the same base clock, the same boost clock, and only differ in this capacity.
The benefit, therefore, is the difference in pricing. The GeForce RTX 5060 Ti 16GB has a launch MSRP of $379, while the GeForce RTX 5060 Ti 8GB has a launch MSRP of $429. This allows a gamer to potentially purchase the same GPU rendering performance at a lower price. In today’s volatile memory market, where RAM and VRAM prices are skyrocketing and availability is in question, it is the perfect time to evaluate the differences in performance you might expect.
In order to do this, we have evaluated the GeForce RTX 5060 Ti 16GB versus GeForce RTX 5060 Ti 8GB in thirteen games, at 1440p native resolution, 1440p with DLSS Upscaling, Ray Tracing, and 4K with DLSS Upscaling. We have tested various game quality settings, DLSS Upscaling qualities, and looked at both average FPS and 1% Low performance to find what is playable, and how they differ.
Performance
Let’s start off by talking about playable gameplay experience and performance. The GeForce RTX 5060 Ti ended up being a capable video card, playing many games at 1440p native resolution. Naturally, older games performed better in this area, while some newer games were very demanding. In the games that were demanding at 1440p native resolution, it was generally while using the game’s highest graphics quality setting. Therefore, lowering the game settings down from the Epic or Ultra settings, down to High, for example, greatly improved the performance and allowed both the GeForce RTX 5060 Ti 16GB and GeForce RTX 5060 Ti 8GB video cards to play well.
There is also the option of enabling DLSS Upscaling at 1440p, and generally, the “Quality” setting of that is playable. You can always lower this to “Balanced” in the games that are very demanding at Ultra settings. Now that DLSS 4.5 is supported, image quality for lower resolution DLSS Upscaling is very good. When it comes to 4K gaming on the GeForce RTX 5060 Ti, well, it is actually usable in some games, with DLSS Upscaling enabled. There are some games that enabling DLSS Upscaling Balanced allows the game to be very playable at 4K. In others, you may have to turn down the game graphics quality setting a bit, or use the Performance or Ultra Performance DLSS Upscaling options. Now that DLSS 4.5 is out, the lower DLSS Upscaling settings at 4K look pretty good and make that viable.
When looking specifically at GeForce RTX 5060 Ti 16GB versus GeForce RTX 5060 Ti 8GB in performance, there was a consistent trend toward the GeForce RTX 5060 Ti 16GB being advantageous in gameplay performance. While there were some outliers, drastic average FPS differences, the primary differences in gameplay performance came by way of the 1% Lows or minimum framerates.
The GeForce RTX 5060 Ti 16GB offered higher and more consistent 1% Low and minimum framerates while gaming. This was seen in many games at the highest in-game settings at 1440p native resolution. However, we did see many cases where even enabling DLSS Quality Upscaling at 1440p still displayed improvements with the GeForce RTX 5060 Ti 16GB compared to the GeForce RTX 5060 Ti 8GB. When trying to run Ray Tracing or Path Tracing, the GeForce RTX 5060 Ti 16GB video card had a clear advantage as Ray Tracing does demand a lot of VRAM.
When running at 4K, this was a bit different because to get a playable performance, you have to run at such a compromised DLSS Upscaling setting that the render resolution is much lower, thus reducing VRAM constraints. This can also occur at 1440p, if running more aggressive DLSS Upscaling, or lower in-game settings. As you lower the in-game settings, VRAM is less constrained, and the GeForce RTX 5060 Ti performance normalizes between a 16GB and 8GB video card. Indeed, even in some games at max settings, 1440p native, performance was the same between the GeForce RTX 5060 Ti 16GB and the GeForce RTX 5060 Ti 8GB. At the end of the day, it is very game-dependent.
If you walk away from this review with one thing in mind: Never feel ashamed of buying an 8GB GeForce RTX 5060 Ti to save money. It is ok, really.
We have previously reviewed the PNY GeForce RTX 5060 Ti 8GB Overclocked Dual Fan Video Card. In that review, we focused on the 1080p gameplay experience and found it to be quite capable of providing a solid gameplay experience at 1080p native resolution. We have also shown in this review today that the GeForce RTX 5060 Ti 8GB can be capable at 1440p, depending on the settings used. In some games, native resolution is playable; in others, lowering the in-game graphics settings or utilizing DLSS Upscaling does the trick.
The GeForce RTX 5060 Ti 8GB is an option to save money if you want GeForce RTX 5060 Ti render performance in games, but cannot afford the 16GB variant. If you find a good deal, and you save a worthwhile amount of money doing so, then an 8GB GeForce RTX 5060 Ti will certainly be faster than a GeForce RTX 5060 in games. You just have to know where the limitations are and work around them, which we have shown is possible. Now that DLSS 4.5 has been released, DLSS Upscaling image quality at lower Upscaling settings also looks really good, giving you an option for more aggressive Upscaling settings.
Generally speaking, the GeForce RTX 5060 Ti 16GB will be preferred for modern games and for games moving forward. If you are focused on the 1440p gameplay experience, then the GeForce RTX 5060 Ti 16GB is the better option. It will allow smoother 1% Lows and higher minimum framerates in games, creating a more consistent gameplay experience. It will also allow higher in-game quality settings to be used or higher resolutions. However, the downside is the pricing for such video cards in today’s memory climate, which is why you might be eyeballing the 8GB GeForce RTX 5060 Ti.
When all is said and done, it comes down to your budget, and if you can snag a GeForce RTX 5060 Ti 8GB video card for significantly less in pricing than a comparable GeForce RTX 16GB video card, then you win. Don’t let anyone shame you out of it; it can deliver a solid gameplay experience in today’s games at the right settings. It supports DLSS 4 and DLSS 4.5, and all the features within. If you can pony up a bit more cash to get you over to the next threshold, then the GeForce RTX 16GB video card will give you more headroom and let that GeForce RTX 5060 Ti truly purr, but if you cannot, don’t sweat it. Happy Gaming.
