Fractal Design Announces “North XL” Case with Full-Size Wood Paneling and a Built-In Cutting Board
When Fractal Design launched the original North in 2022, the walnut front panel was polarizing in the way that good industrial design sometimes is: you either immediately understood it or you found it confusing that someone had put wood on a PC. The design won enough converts that Fractal has since expanded the line, and today the company has announced the North XL, a full-tower version of the North that ships with a removable, food-safe walnut cutting board designed to mount magnetically to the top panel. It seems that the wood trend is sweeping the industry, as the GIGAGBYTE X870E AERO X3D WOOD Motherboard would be a perfect match.
The cutting board is oiled with food-safe mineral oil and sized at 280mm x 180mm, fitting neatly over the top panel mesh while leaving the fan mount positions accessible at the sides. It attaches via four rare-earth magnet points embedded in the case’s top panel, supports up to 3kg of lateral loading (per the spec sheet), and is dishwasher safe. Fractal’s press release notes that the cutting board “pairs naturally with the North XL’s placement in open, lifestyle-oriented desk environments” and that it “should not be used while the PC is transferring large files, as a precaution.”
Sharky Extreme’s hands-on confirms the magnetic attachment is solid and that the board is “genuinely a nice cutting board, independent of its PC-adjacent identity.” The North XL itself is a substantial E-ATX chassis supporting radiators up to 420mm in the front and 360mm on top, with tool-free drive mounting throughout. Tempered glass side panel is standard.
Pricing is $209 for the standard version and $229 for the North XL Walnut Bundle that includes the cutting board. The cutting board is also sold separately for $34 for existing North owners who have decided their PC is also kitchen infrastructure now. Available April 1 in black and white chassis options, walnut or solid oak front panel.
This is a product that should not work as a concept and does anyway, which is basically the Fractal North story in miniature. A++ for commitment to the bit. Let us know your thoughts in the forums.
