Transient Testing
Transient Test 1
Loaded/Unloaded
12v/5v
Test #1 is equal to approximately 25% of the rated capacity of the SilverStone ST1200-PTS at 45c. This makes Test #1 equal to 303W by loading the 12v rail to 23a, the 5v rail to 2a, the 3.3v rail to 1a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #1 show a ~300mV drop on the 12v rail and ~90mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~60mV drop.
Transient Test 2
Loaded/Unloaded
12v/5v
Test #2 is equal to approximately 50% of the rated capacity of the SilverStone ST1200-PTS at 45c. This makes Test #2 equal to 595W by loading the 12v rail to 46a, the 5v rail to 4a, the 3.3v rail to 3a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #2 show a ~280mV drop on the 12v rail and ~80mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~40mV drop.
The Transient Load Tests results for the SilverStone ST1200-PTS are passing and good. In today’s testing, the ST1200-PTS saw the loaded 12v rail post a peak change of ~300mV and the loaded 5v rail post a peak change of ~90mV. The unloaded 5v peak change during the 12v load was ~60mV. Those numbers are passing and good in an absolute sense. In a relative sense it is tougher to say as we do not have another 1200W unit to compare this too. That said, even with this unit being 1200W, and a few individual values being bigger than we might expect, this unit is not throwing up any red flags and it is likely competitive with many other 1200W units on the market. Let’s move on now to see how this unit does in the DC Output Quality aspect of our testing!
