Not content with having just released the world’s fastest gaming monitor ASUS released another first last week at CES. This time around they bring the ROG Swift PG43UQ gaming monitor to the table.
Specifications:
- Size: 43″
- Resolution: 3840×2160
- Panel Type: VA
- Refresh Rate: 144Hz
- Adaptive Sync: G-Sync Certified
- Response Time: 1ms MPRT
- Display HDR1000
- Color: 90% DCI-P3
- Contrast Ratio: 4000:1
- Connectivity: 2 x HDMI 2.0, 2 x Display Port 1.4 with DSC
- Audio: 2 x 10W Speakers, 3.5mm in/3.5mm out
- USB: 2 x USB 3.0
It goes without saying that it would take a powerful system to pump out 144 frames at 4K but with G-Sync they’ve got you covered for tearing issues. What makes this a first is that the monitor supports DSC or Display Steam Compression. This newer standard is what enables them to support that 144Hz/10bit color over DP 1.4. No U.S. prices have been announced but OC3D reported on seeing them at OVERCLOCKERS U.K. for £1,538.95. ASUS states that the response time is with internal testing and may vary under other test conditions.
