The new Define 7 Compact takes the strongest features of the contemporary 7 Series design and places them in a conveniently compact frame.
The versatile open layout of the Define 7 Compact allows you to maximize the potential of the small footprint with full-size ATX hardware to meet your exact needs.
Interchangeable top covers allow you to switch between solid steel for full noise suppression or a ventilated cover for extra cooling.
The top framework is fully removable for unprecedented ease of access to interior components, and five front ports (including one USB Type-C) means you don’t sacrifice expandability for the small footprint.
Add to that the numerous enhancements to every aspect of component and cooling support, and it’s clear to see the Define 7 Compact has you well covered.
Specifications
- 3.5″/2.5″ Universal drive brackets: 2
- Dedicated 2.5″ drive brackets: 2 trays included, 4 positions total
- Expansion slots: 7
- Front ports: 1x USB 3.1 Gen 2 Type-C, 2x USB 3.0, 2x USB 2.0, Audio I/O, Power button, Reset button
- Total fan mounts: 7x 120 or 4x 140 mm and 2x 120 mm
- Front fan: 3x 120 or 2x 140 mm, (1x Dynamic X2 GP-14 included)
- Top fan: 2x 120 or 2x 140 mm
- Rear fan: 1x 120 mm, (1x Dynamic X2 GP-12 included)
- Bottom fan: 1x 120 mm (requires removal of HDD cage)
- Dust filters: Top, 2x front, full length bottom
- Fixed velcro straps: Yes
- Cable routing grommets: Yes
- Captive thumbscrews: HDD brackets, SSD brackets, PSU bracket
- Left side panel: Industrial sound-damped steel
- Right side panel: Industrial sound-damped steel
Compatibility
- Motherboard compatibility: ATX / mATX / Mini-ITX
- Power supply type: ATX
- PSU max length: 200 mm (with HDD cage and front fan)
- GPU max length: 341 mm (360 mm without front fan)
- CPU cooler max height: 169 mm
- Front radiator: Up to 360/280 mm (max 145 mm width)
- Top radiator: Up to 240 mm
- Rear radiator: 120 mm
- Bottom radiator: 120 mm (requires removal of HDD cage)
- Cable routing space: 17-28 mm
Dimensions
- Case dimensions (LxWxH): 427 x 210 x 474 mm
- Case dimensions w/o feet/protrusions/screws: 415 x 210 x 451 mm
- Package dimensions (LxWxH): 536 x 310 x 521 mm
- Net weight: 8.61 kg
- Package weight: 10.87 kg
- Volume: 39.3 liters
