Thermaltake, the leading PC DIY premium brand for Cooling, Gaming Gear, and Enthusiast Memory solutions, proudly presents the first-ever product that combines memory and an AIO liquid cooler, the Floe RC360 / RC240 CPU & Memory Liquid Cooler. Thermaltake never stops to seek out possibilities to impress our users with a more efficient cooling solution for our memory modules. With the new Floe RC360 / RC240 CPU & Memory Liquid Cooler, users can acquire an unparalleled gaming experience.
Floe RC360 / RC240 CPU & Memory Liquid Cooler is compatible with TOUGHRAM RC memory modules (Sold separately) and grants further expandability which allows users to equip a high-quality all-in-one cooling system, including a water block, radiator, an ARGB controller, and three high airflow 120mm fans on the RC360 version and two high airflow 120mm fans on the RC240 version.
Other than that, Floe RC360/RC240 CPU & Memory Liquid Cooler can be synchronized with motherboards equipped with 5V addressable RGB headers such as ASUS Aura Sync, GIGABYTE RGB Fusion, MSI Mystic Light Sync, Biostar VIVID LED DJ and ASRock Polychrome, allowing users to control the lights directly from the motherboards RGB lighting software.
For more product and 2020 Thermaltake EXPO June information, please visit https://expo2020.thermaltake.com/
Features of the Floe RC360 / RC240 CPU & Memory AIO Liquid Cooler:
Motherboard RGB Sync Ready
Designed to synchronize with ASUS Aura Sync, GIGABYTE RGB Fusion, MSI Mystic Light Sync, Biostar VIVID LED DJ, and ASRock Polychrome. The Floe RC360 / RC240 CPU & Memory Liquid Cooler supports motherboards equipped with 5V addressable RGB headers, allowing you to control lighting effects directly from the software mentioned above without installing any extra lighting software or controllers.
ARGB Sync Radiator 120mm Fan
The product is equipped with Thermaltake’s 120mm ARGB Sync Radiator Fan. It features compression blades, hydraulic bearings, and a 16.8 million color LED ring with nine addressable LEDs that are ready to sync with 5V RGB capable motherboards.
High-Efficiency Radiator
Specially designed with a large surface radiator, Floe RC360/RC240 CPU & Memory Liquid Cooler increases heat dissipation.
High-Performance Water Block
The high-performance copper base plate accelerates heat conductivity. The pre-filled coolant reduces any hassle for liquid replenishment. Additionally, the reinforced sleeved cables deliver heavy durability and prevent the tubing from any damage.
Hardware Supported
It can support the latest Intel and AMD CPU and compatible with universal sockets (including Intel LGA 1200).
Memory Water Block Lighting
The waterblock for the memory strips are equipped with four lighting strips, featuring 36 addressable LEDs that allows users to show their RGB lightings.
Compatibility
Floe RC360/RC240 CPU & Memory Liquid Cooler is compatible with TOUGHRAM RC DDR4 Memory Modules – Our modules feature the same quality that customers expect from the TOUGHRAM Memory line. Launching in frequencies of 3,200MHz, 3,600MHz, 4,000MHz, and 4,400MHz in kits of 8GBx2 modules; users may find a configuration to fit any PC allowing installation capacity of up to 32GB on mainstream 4-DIMM slots.
More information on the TOUGHRAM RC DDR4 Memory Modules:
Tightly-Screened ICs
Memory chips are thoroughly-screened to provide optimal frequency and response time performance.
Intel XMP 2.0 Ready
Overlock with ease and optimize system stability with a simple setting.
Availability, Warranty and Pricing
Thermaltake Floe RC360 / RC240 CPU & Memory AIO Liquid Cooler will be available for purchase in Q3 2020 via the Thermaltake worldwide network of authorized retailers and distributors. These two products are backed by a two-year warranty and supported by the Thermaltake worldwide customer service and technical support network. For up-to-date pricing of the Thermaltake Floe RC360 / RC240 CPU & Memory Liquid Cooler, please refer to the Thermaltake website or contact your local Thermaltake sales or PR representative.
