Transient Testing
Transient Test 1
Loaded/Unloaded
12v/5v
Test #1 is equal to approximately 25% of the rated capacity of the Phanteks AMP 750 at 45c. This makes Test #1 equal to 184W by loading the 12v rail to 13a, the 5v rail to 2a, the 3.3v rail to 1a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #1 show a ~250mV drop on the 12v rail and ~50mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~45mV drop.
Transient Test 2
Loaded/Unloaded
12v/5v
Test #2 is equal to approximately 50% of the rated capacity of the Phanteks AMP 750 at 45c. This makes Test #2 equal to 343W by loading the 12v rail to 21a, the 5v rail to 4a, the 3.3v rail to 2a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #2 show a ~280mV drop on the 12v rail and ~45mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~40mV drop.
The Transient Load Tests results for the Phanteks AMP 750 are passing and excellent to boot! In today’s testing, the AMP 750 saw the loaded 12v rail post a peak change of ~280mV, and the loaded 5v rail post a peak change of ~50mV. The unloaded 5v peak change during the 12v load was ~45mV. Those numbers are, in an absolute sense, excellent! Now, we do not have another 750W unit to compare this one too. However, it is safe to say that, based on what we have seen over the years, these values would be more than competitive with excellent 750W units without a doubt. So, this is a very nice set of results for the AMP 750 today. Let’s move on now to see how this unit does in the DC Output Quality aspect of our testing!
