Test Setup
We will use our standard AIO test rig which you can read more about in its introduction article. We will set up each cooler in the same manner with the radiator attached to the case and the fans blowing into the radiator. The water blocks will be mounted per the manufacturer’s instructions except that we will use Arctic Cooling MX-2 thermal paste (2019 Edition). We will also compare it to the other coolers we have tested thus far.
Installation
Installation was straightforward on our test bench. We strapped the radiator into place and the water block went on without any hassle. The power wire for the pump was a bit on the short side, which would not allow us to wire it through the back of the case, but we were able to route it alongside the memory without much difficulty.
With everything comfortably situated, lets start seeing what kind of numbers the Enermax AQUAFUSION 240 can put up today!
