Those looking to upgrade or replace an older gaming monitor may want to check this one out. GIGABYTE has released its G27F-SA monitor, which packs many premium features for a very affordable price. At a time when displays are getting bigger and more expensive, there are many still holding on to the more traditional, flat-panel 27-inch designs. For $249.99, this one could have you wondering about making a new purchase.
Specifications
- Panel Size: (diagonal)27” IPS
- Display Viewing Area: (HxV)597.6*336.15
- Panel Backlight/ Type: Edge type
- Display Surface:(non-glare/ glare)Non-glare
- Color Saturation: 95% DCI-P3 / 125% sRGB
- True Resolution1920 x 1080 (FHD)
- Brightness: 300 cd/m2 (TYP)
- Contrast Ratio: 1000:1
- Dynamic Contrast Ratio:12M:1
- Viewing Angle: 178°(H)/178°(V)
- Color Depth: 8 bits
- Response Time:1ms (MPRT)
- Refresh Rate:144Hz
- VRR: FreeSync Premium and G-Sync Compatible Ready
- Flicker-free:Yes
- HDR: No
- Signal Input: HDMI 1.4 x2, Display port 1.2 x1
- Earphone Jack: Yes
- Speaker: 2W x2
- USB port(s): USB 3.0 x2
- Power Type: Power adapter
- Power Consumption: 60W(Max)
- Voltage: 19VDC 3.42A
- Tilt(angle): -5°~+20°
- Height Adjustment: (mm)130mm
- VESA Wall Mounting: (mm)100*100mm
- Kensington lock: Yes
- Phys. Dimension with Stand: (WxHxD)619.04*518.88*202.97
- Phys. Dimension w/o stand: (WxHxD)619.04*365.526*56
- Box Dimension: (WxHxD)737*218*495mm
- Net Weight: (Esti.)6.6
- Gross Weight: (Esti.)9.3
- Accessories: Power cable/HDMI cable/DP cable/ USB cable/QSG/Warranty card
This particular variant in the G26F lineup has few distinctions from another model, the G27FC. The G27F-SA is a flat IPS panel with 144 Hz refresh rate vs. the 1500R curved VA 165 Hz panel of the G27FC. The G27F-SA is also slightly brighter at 300 cd/m2 vs. 250 cd/m2 of the G27FC.
