Square Enix has released the minimum and recommended specifications for Crystal Dynamics’ Avengers game, which hits Steam on September 4. There’s nothing particularly surprising here, aside from the implication that it’s best played on an SSD (traditionally, it’s open-world games that see big benefits from solid state storage, so we’re not sure if Avengers will load all that differently on a standard HDD).
What’s more exciting is the optional 30 GB high-resolution texture pack that’s mentioned, which should improve the graphics substantially. “Forests will feel lusher, the tundra more frigid, and AIM facilities all the more sinister to really bring the experience to life,” wrote Square Enix. “Additionally, there will be support for ultra-wide resolutions as well as multi-monitor configurations so Marvel’s Avengers will look good no matter your set up.”
Marvel's Avengers on PC will come with features that take advantage of its capabilities. PC players, we can't wait to see you in the BETA!
— Marvel's Avengers (@PlayAvengers) August 12, 2020
🖥️ Details and PC specs available now: https://t.co/GwIkr5gvLb pic.twitter.com/2YBnH6mXs9
“In order to give you the smoothest experience we can that fits your particular gaming comforts, there will be fully unlocked frame rate to support extremely responsive 144 Hz gameplay on capable systems,” the company added. “There will also be fully configurable keyboard and mouse controls with many customization options to tune them to your play style and the ability to seamlessly switch between controllers and keyboard/mouse and use our recommended controller configuration or have the option to fully customize their layout to your liking.”
Minimum Spec:
- OS: Windows 10 64-bit
- CPU: i3-4160 or AMD equivalent
- 8GB RAM
- NVIDIA GTX 950 / AMD 270 (min 2GB video ram)
- DirectX 12
- 75GB HDD space
Recommended Spec:
- Windows 10 64-bit
- CPU: Intel Core i7 4770K, 3.4 Ghz or AMD Ryzen 51600, 3.2 Ghz
- 16GB RAM
- NVIDIA GTX 1060 6GB or AMD Radeon RX 480, 8GB.
- DirectX 12
- 110GB SSD space
