Transient Testing
Transient Test 1
Loaded/Unloaded
12v/5v
Test #1 is equal to approximately 25% of the rated capacity of the FSP Hydro G PRO 1000W at 45c. This makes Test #1 equal to 268W by loading the 12v rail to 20a, the 5v rail to 2a, the 3.3v rail to 1a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #1 show a ~210mV drop on the 12v rail and ~45mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~35mV drop.
Transient Test 2
Loaded/Unloaded
12v/5v
Test #2 is equal to approximately 50% of the rated capacity of the FSP Hydro G PRO 1000W at 45c. This makes Test #2 equal to 492W by loading the 12v rail to 38a, the 5v rail to 3a, the 3.3v rail to 2a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #2 show a ~200mV drop on the 12v rail and ~40mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~35mV drop.
The Transient Load Tests results for the FSP Hydro G PRO 1000W are excellent in an absolute sense. The peak 12v change when loaded was ~210mV while the 5v rail when loaded saw a peak change of ~45mV. The peak 5v change when the 12v rail was loaded was ~35mV. In addition to these results being excellent in an absolute sense, these results are better than what we saw from the SilverStone ST1000-PTS. So, the Hydro G PRO 1000W certainly has this aspect of testing nailed! Let’s move on now to see how this unit does in the DC Output Quality aspect of our testing!
