Ubisoft has revised the official PC specifications for Watch Dogs: Legion, which were originally released in September. Those of you who plan to hack through post-Brexit London in the game’s 4K Ultra settings with ray-tracing enabled will definitely need to step up to NVIDIA’s new flagship GPU, the GeForce RTX 3080. Otherwise, a GeForce RTX 2080 Ti is acceptable for players who simply want to play the game in 4K at its highest visual quality, sans ray tracing.
The original specifications sheet included AMD’s Radeon VII under the 4K Ultra Settings column, but that’s been replaced by the GeForce RTX 2080 Ti. NVIDIA’s GeForce GTX 960 has also been switched out for the GeForce GTX 970 under the low (1080p) preset.
Ray Tracing Enabled
Minimum System Requirements – 1920×1080, High preset, Ray Tracing Medium, DLSS Quality, DX12 only
- CPU: Intel Core i5-8400 2.8 GHz, AMD Ryzen 5 2600 3.4 GHz
- GPU: NVIDIA GeForce RTX 2060
- Video memory: 6GB
- RAM: 16GB (Dual-channel setup)
- Hard Disk Space: (45GB)
- OS: Windows 10 (64 bit only)
Recommended System Requirements – 2560×1440 (1440p), Very High preset, Ray Tracing High, DLSS Quality, DX12 only
- CPU: Intel Core i7-9700 3.0 GHz, AMD Ryzen 5 3600 3.6 GHz
- GPU: NVIDIA GeForce RTX 3070
- Video memory: 8GB
Ultra-System Requirement – 3840×2160 (4K), Ultra preset, Ray Tracing Ultra, DLSS Performance, DX12 only
- CPU: Intel Core i9-9900K 3.6 GHz, AMD Ryzen 7 3700X 3.6 GHz
- GPU: NVIDIA GeForce RTX 3080
- Video memory: 10 GB
- Hard Disk Space: 45GB (+20 GB HD Texture Pack)
Ray Tracing Disabled
Minimum System Requirements for 1920×1080, Low Preset, DX12
- CPU: Intel Core i5-4460 3.2 GHz, AMD Ryzen 5 1400 3.2 GHz
- GPU: NVIDIA GeForce GTX 970/GeForce GTX 1650
- Video memory: 4GB
- RAM: 8GB (Dual-channel setup)
Recommended System Requirements for 1920×1080, High Preset, DX12
- CPU: Intel Core i7-4790 3.6 GHz, AMD Ryzen 5 1600 3.2 GHz
- GPU: NVIDIA GeForce GTX 1060/GeForce GTX 1660 Super
- Video memory: 6GB
Recommended System Requirements for 2560×1440, High Preset, DX12
- GPU: NVIDIA GeForce RTX 2060 Super
- Video memory: 8GB
Ultra-System Requirement – 3840×2160 (4K), Ultra Preset DX12
- CPU: Intel Core i7-9700K 3.6 GHz, AMD Ryzen 7 3700X 3.6 GHz
- GPU: NVIDIA GeForce RTX 2080 Ti or GeForce RTX 3080
- Video memory: 10GB
- OS: Windows 10 (64 bit only) (For optimal experience use DX12, also compatible with “DX11”)
“Watch Dogs: Legion is also scheduled for release on Xbox One, PS4, and Stadia on October 29, as well as Xbox Series X | S on November 10 and PlayStation 5 on November 12,” Ubisoft noted. “Watch Dogs: Legion will also be available on Amazon Luna when the Ubisoft channel launches. For more information on the game, check out our previous coverage.”
