Antec Neo ECO GOLD ZEN 700W Power Supply Review
Transient Testing
Transient Test 1
Loaded/Unloaded
12v/5v
Test #1 is equal to approximately 25% of the rated capacity of the Antec Neo ECO Gold ZEN 700W at 45c. This makes Test #1 equal to 184W by loading the 12v rail to 13a, the 5v rail to 2a, the 3.3v rail to 1a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #1 show a ~400mV drop on the 12v rail and ~80mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~60mV drop.
Transient Test 2
Loaded/Unloaded
12v/5v
Test #2 is equal to approximately 50% of the rated capacity of the Antec Neo ECO Gold ZEN 700W at 45c. This makes Test #2 equal to 325W by loading the 12v rail to 24a, the 5v rail to 3a, the 3.3v rail to 2a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #2 show a ~310mV drop on the 12v rail and ~70mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~60mV drop.
The Transient Load Tests results for the Antec Neo ECO Gold ZEN 700W are passing and good if you look at them in the right context. In today’s testing, the Neo ECO Gold ZEN 700W saw the loaded 12v rail post a peak change of ~400mV, and the loaded 5v rail post a peak change of ~80mV. The unloaded 5v peak change during the 12v load was ~60mV.
Those numbers are, in an absolute sense, passing. The 12v rail, however, was a little less than good. Now, when we look at comparable units like the Cougar BXM 700 we see that it soundly beats this unit. So, like the Cougar BXM 700, this is a more mainstream/value-oriented offering which makes these test results a bit more forgivable than they would be for a higher-end model. So, let’s move on now to see how this unit does in the DC Output Quality aspect of our testing!
Paul Johnson
