Meet the newly upgraded Razer Tomahawk modular gaming desktop. Don’t let the size of this small-form-factor (SFF) PC fool you. Underneath that metal chassis lies some powerful equipment. Remember when we reported on Intel’s new NUC 9 mini PC? Razer has taken that and paired it with NVIDIA’s GeForce RTX 3080 to make an impressive gaming solution.
Specifications
| PRODUCT NUMBER | RZ42-03650200 |
| CASE MATERIAL | All Metal Chassis |
| PROCESSOR | 9th Gen Intel Core i9-9980HK Clock Speed: 2.4GHz / 5.0GHz (Turbo), 8 Core, 16 Thread, 16MB Cache |
| GRAPHICS CARD | Unpopulated PCIe Slot (PCIe x16) |
| STORAGE | 512GB PCIe NVMe + 2TB HDD (5400 RPM) |
| ADDITIONAL STORAGE | Unpopulated M.2 Slot |
| MEMORY | 16GB DDR4 2667MHz |
| WI-FI | Wi-Fi 6 (AX200) |
| BLUETOOTH | Bluetooth 5.0 |
| USB PORTS | 4x USB3.2 Gen 2 Type A 2x USB3.2 Gen 2 Type C (Thunderbolt 3 Ports) |
| THUNDERBOLT 3 | 2x Thunderbolt 3 |
| AUDIO PORTS | 3.5mm Line Out / Optical Out 3.5mm Headset Port |
| ACTIVE COOLING | 2x 120mm Fans |
| POWER SUPPLY | 750W |
| COLOR | Black |
| CHROMA INTEGRATION | Chroma Base |
Don’t feel like you want the GeForce RTX 3080? That’s okay because the Tomahawk is designed for full-sized GPUs. You can order it without one and provide your own. Using a tool-less sled, owners can remove the core components simply by pulling on a handle. With the default graphics solution, the Tomahawk is priced at $2399.99.
