GIGABYTE has announced its AORUS Gen4 7000s SSDs. Available in 1 TB and 2 TB models, these M.2 2280 drives offer an impressive sequential read speed of up to 7,000 MBs and sequential write speed of up to 6,850 MB/s (5,500 MB/s for the 1 TB model). Users can expect 55 percent faster performance over previous PCIe 4.0 NVMe SSDs thanks to the implementation of Phison’s latest E18 controller and high-speed 3D-TLC NAND Flash.
GIGABYTE did not share the AORUS Gen4 7000s SSDs’ pricing or dates of availability, but you can check out an overview of their specifications below. The manufacturer has also shared CrystalDiskMark results to prove their advertised sequential read and write speeds.
Specifications
AORUS Gen4 7000s SSD 2TB
- Form Factor: M.2 2280
- Interface: PCI-Express 4.0 x4, NVMe 1.4
- Total Capacity: 2000GB*
- Sequential Read Speed : up to 7000 MB/s**
- Sequential Write speed : up to 6850 MB/s**
- Wear Leveling, Over-Provision technologies
- TRIM & S.M.A.R.T supported
- AES-256 Supported
- High Efficient Heat Spreader with Nanocarbon Coating
- Warranty: Limited 5-years
AORUS Gen4 7000s SSD 1TB
- Total Capacity: 1000GB*
- Sequential Write speed : up to 5500 MB/s**
- AES-256 Supported
Gallery and Benchmarks
Original Press Release
Gigabyte Technology, one of the top global manufacturers of motherboards, graphics cards, and hardware solutions, announces today the latest AORUS Gen4 7000s SSD with up to 7GB/s read speed. Enhanced by the new generation PCIe 4.0 controller with advanced 3D-TLC NAND Flash, it boosts up to 55% more performance than previous generation PCIe 4.0 NVMe SSD. AORUS Gen4 7000s SSDs come in two capacity variants, 2TB and 1TB with M.2 2280 interface to make installation easy. They equip big aluminum thermal interface in different sizes and double side thermal pad with Nanocarbon coating for improved heat dissipation. Meanwhile, the SSD Tool Box application provides the instant overview and adjustment of SSD status.
“The storage devices are taking advantage of the PCIe 4.0 transfer speed that raised from 5GB/s to almost 8GB/s, which is great news for users who expect to optimize storage performance and reduce the bottle neck of system operation.” said Jackson Hsu, Director of the GIGABYTE Channel Solutions Product Development Division. “AORUS Gen4 7000s SSDs further advance the standards set by our previous SSD products to provide users with breakthrough performance. After the OS installed, uses can enjoy unprecedented 7GB/s read speed with 1TB or 2TB storage capability. The thermal solution and the double-sided thermal pad are designed to slow down the throttling that might occur at high-speed operation of SSD, thus boost the system performance.”
AORUS Gen4 7000s SSDs equip the latest Phison E18 selected 8-channel controller, which provides users with ultimate random access rate, as well as the high speed 3D-TLC NAND Flash and SLC cache design that brings the PCIe 4.0 into full play. Under the real test, AORUS Gen4 7000s SSD features read speed up to 7GB/s and write speed up to 6.85GB/s, which is 55% faster than PCIe 4.0 NVMe SSD, two times faster than PCIe 3.0 SSD, and up to 13 times faster than SATA SSD. Enhanced by Phison’s E18 controller, AORUS Gen4 7000s SSD not only improves AI multitasking operation, but power up content creators, gamers, and users eager for extreme performance.
The high-speed SSD generates heat on full speed operation, and normally thermal throttling is implemented as a safety feature to prevent data loss, or wear-out the memory chips and controllers. The throttling state engages to maintain the stability and durability, however it slows down the performance and it reduces the transfer rate. In order to keep AORUS Gen4 7000s SSD cool while it is running at high speed, GIGABYTE employs the special-designed double-sided aluminum heatsink with Nanocarbon coating. By utilizing the clearance area smartly between slots on motherboards, the size of the thermal fins can be maximized to enlarge the surface area of dissipation. This design can support different M.2 slots perfectly on various motherboards to avoid possible interference by VGA cards installed above the M.2 SSD. AORUS Gen4 7000s SSD also equip high conductivity thermal pad to improve heat dissipation 30% better than metal thermal pad.
For those progressive M.2 users who prefer more extreme thermal solution without installing SSDs between PCIe expansion slots, AORUS Gen4 7000s SSD comes in another version of heatsink with integrated heatpipes. With the same double-sided heat spreader with Nanocabon coating and high conductivity pad design, but optimized on the height and dissipation area, AORUS Gen4 7000s SSD promises the consistent cooling and high performance for those water cooling users to avoid throttling from the overheating caused by no air flow assistance of the CPU fan. Users can customize their thermal allocation according to personal needs by GIGABYTE’s thoughtful design, which balances between the high performance and low temperature.
AORUS Gen4 7000s SSD features PCIe 4.0 NVMe M.2 interface design. To release the breakthrough performance of read speed up to 7GB/s , AMD X570 / B550 motherboards or Intel Z490 motherboards with next-gen Intel® Core™ processors supported are highly-recommended. With GIGABYTE R&D’s professional adjustment, comprehensive verification, software enhancement, and the 5 years warranty service, GIGABYTE motherboards offers more stability with higher performance, which is definitely the best choice for users.
