Razer has announced its new Razer Blade 15 gaming laptops, which come in Advanced and Base configurations with FHD 144/360 Hz, QHD 165/240 Hz, or 4K OLED Touch displays, NVIDIA GeForce RTX 30 series GPUs, and 6/8-core Intel Core processors. Storage options include a 512/1 TB SSD with an open M.2 PCIe 3.0 slot (expandable up to 4 TB). The base model has 16 GB of DDR4 memory, while the Advanced is available with either 16 or 32 GB DDR4 memory. Memory is expandable up to 64 GB.
Advanced Model | Base Model | |
OS | Windows 10 Home | Windows 10 Home |
Processor | 8-Core Intel® Core™ i7-10875H 8 Cores (2.3GHz / 5.1GHz) | 6-Core Intel® Core™ i7-10750H 6 Core (2.6GHz / 5.0GHz) |
Graphics | Up to GeForce RTX™ 3080 | Up to GeForce RTX™ 3070 |
Display Options | FHD 360 Hz, QHD 240 Hz or 4K OLED Touch 60 Hz | FHD 144 Hz or QHD 165 Hz |
Storage | 1 TB PCIe Extra M.2 PCIe Slot | 512 GB PCIe Extra M.2 PCIe Slot |
Memory | 16 GB or 32 GB RAM | 16 GB RAM |
Cooling | Vapor Chamber | Advanced Heat pipe |
Keyboard | Per-key RGB Razer Chroma | Single-zone RGB Razer Chroma |
Other Ports | SD Card Reader | Gigabit Ethernet |
Approx. Height | 0.67” / 16.99 mm | 0.78” / 19.9 mm |
Prices range from $1699.99 to $3299.99. Preorders are open and will begin shipping on March 3.
