Philips has announced a new 28-inch 4K IPS 60 Hz display that appears to be an attractive solution for gaming or productivity. It features various display modes, cable management features, an adjustable stand, stereo speakers, and USB 3.2 ports with fast charge B.C 1.2. It is expected to launch for around £269 (around $300) in February.
Specifications
- LCD panel type: IPS technology
- Backlight type: W-LED system
- Panel Size: 28 inch/71.1 cm
- Display Screen Coating: Anti-Glare, 3H, Haze 25%
- Effective viewing area: 620.93 (H) x 341.28 (V)
- Aspect ratio: 16:9
- Maximum resolution: 3840 x 2160 @ 60 Hz
- Pixel Density: 157 PPI
- Response time: (typical)4 ms (Grey to Grey)*
- Brightness: 300 cd/m²
- Contrast ratio: (typical)1000:1
- SmartContrast: Mega Infinity DCR
- Pixel pitch: 0.16 x 0.16 mm
- Viewing angle: 178º (H)/178º (V) @ C/R > 10
- Picture enhancement: SmartImage game
- Colour gamut: (typical)NTSC 106.9%*, sRGB 119.7%*
- Display colors: Colour support 1.07 billion colors
- Scanning Frequency: 30-140 kHz (H)/40-60 Hz (V)
- SmartUniformity: 93 ~ 105%
- Delta E: < 2 (sRGB)
- Flicker-free: Yes
- LowBlue Mode: Yes
- EasyRead: Yes
- RGB: Yes
- Adaptive sync: Yes
- Signal Input: DisplayPort x 1HDMI (digital, HDCP)
- USB: USB 3.2 x 1 (upstream), USB 3.2 x 4 (downstream with 1 fast charge B.C 1.2)Sync InputSeparate Sync
- Audio (In/Out): Audio out
- Built-in Speakers3 W x 2
- MultiView: PIP/PBP mode 2 x devices
- Height adjustment: 100 mm
- Tilt: -5/20 degree
- Power supply: External 100–240 VAC, 50–60 Hz
- Dimensions: With stand (max height)637 x 494 x 224 mm, without stand 637 x 367 x 41 mm
- Weight: With stand (kg)6.09, without stand (kg)4.27
- Included Cables: DP cable, HDMI cable, Power cable
There is nothing attractive about that display for gaming. For productivity, I’d still argue it sucks because it’s too small physically. You’d almost have to use font scaling to use it, which makes the resolution less effective because of how it forces you to use larger application windows, etc.
Yeah this doesn’t look any different from monitors that have already been on the market for years
Or cheaper?
I guess it’ll depend on how well it performs against its peers. At least it has VRR on the spec list, we’ll see if it’s even useful.
What I will say is that it’s a moderate step in the right direction in terms of pixel density when it comes to scaling. Obviously you’d need at least 150% at normal view distances, but in my recent experience with my 32″ 4k at 150%, that results in a very, very sharp desktop!
