OC Testing
For our OC testing, we have configured our CPU to run 4100MHz on all cores and set the voltage to 1.3875V. This yields an approximate power at the wall of 255w under load (a 197w differential from idle, which pulls about 58w). This results in the CPU running at 4.1GHz on all cores during the looping rounds of Cinebench R20.
Max Fans
Running our HSFs at full tilt lead to the be quiet! Dark Pro 4 is posting a temperature of 78 degrees Celsius. It trailed the Cooler Master Hyper 212 EVO (77.38 degrees Celsius) but bested the Iceberg Thermal IceSLEET X7 Dual (79 degrees Celsius). The max fan speed on the Cooler Master Hyper 212 EVO was 2050 RPM and 1600 RPM on the Iceberg Thermal IceSLEET X7 Dual. The be quiet! Dark Pro 4 was even lower at 1500 RPM.
1500 RPM Fans
At the 1500 RPM fan speed, the be quiet! Dark Rock Pro 4 posted a value of 78 degrees Celsius. The Cooler Master Hyper 212 EVO posted a value of 79.75 degrees Celsius while the Iceberg Thermal IceSLEET X7 Dual was right on its heels at 79.88 degrees Celsius.
1000 RPM Fans
At the 1000 RPM fan speed, the be quiet! Dark Rock Pro 4 posted a value of 82.5 degrees Celsius. The Cooler Master Hyper 212 EVO and Iceberg Thermal IceSLEET X7 Dual both failed to keep the temperature in check here and our system crashed.
Now that we have seen how all of our units cool, lets see if we can still hear!
