GIGABYTE has published the landing page and full specifications for one its most highly anticipated HDMI 2.1 gaming monitors, the AORUS FO48U. A relatively large display, the AORUS FO48U features a 47.53-inch OLED panel offering 4K UHD resolution (3840 x 2160 px), 120 Hz refresh rate, 1 ms GTG response time, 98 percent DCI-P3 color coverage, 130 percent sRGB color coverage, and 135000:1 contrast ratio. Unfortunately, GIGABYTE’s AORUS FO48U does not appear to offer any level of HDR support. Pricing and dates of availability are also unknown at this time.
AORUS FO48U Gaming Monitor Specifications
| Panel Size (diagonal) | 47.53″ OLED |
| Display Viewing Area (HxV) | 1052.16×591.84(mm) |
| Panel Backlight/ Type | OLED |
| Display Surface(non-glare/ glare) | Anti-Reflection |
| Color Saturation | 98% DCI-P3/130% sRGB |
| True Resolution | 3840 X 2160 (UHD) |
| Pixel Pitch | 0.274(H) X 0.274(V) (mm) |
| Brightness | 135 cd/m2 (TYP) |
| Contrast Ratio | 135000:1 |
| Viewing Angle | 178 (H)/178 (V) |
| Display Colors | 10 bits |
| Response Time | 1ms GTG |
| Refresh Rate | 120Hz* |
| HDR | N/A |
| Flicker-free | Yes |
| Signal Input | HDMI 2.1 X2 Display port 1.4 (DSC) x1 |
| HBR3 | Yes |
| Earphone Jack | Yes |
| Microphone Jack | N/A |
| Speaker | 15W x2 + 20W X1 |
| Unique Features | OSD Sidekick Aim Stabilizer Sync Black Equalizer 1.0 Dashboard Timer Counter Crosshair PiP/PbP Auto-Update KVM 6 axis Color Control Smart OD |
| USB port(s) | USB 3.0 x2 USB C X1 |
| Power Type | Built-in |
| Power Consumption | 325W (Max) |
| Power Saving Mode | 0.5W |
| Power Off Mode | 0.3W |
| Voltage | AC 100V~240V |
| Tilt(angle) | N/A |
| Swivel(angle) | N/A |
| Pivot(angle/direction) | N/A |
| Height Adjustment (mm) | N/A |
| VESA Wall Mounting(mm) | 300*300 |
| Kensington lock | Yes |
| Phys. Dimension with Stand(WxHxD) | 1068.5*675.1*251.1 |
| Phys. Dimension w/o stand (WxHxD) | 1068.5*611.8*43.1 |
| Box Dimension (WxHxD) | 1180*760*160 |
| Net Weight with stand (Esti.) | 15 kg |
| Net Weight without stand (Esti.) | 14 7kg |
| Gross Weight (Esti.) | 20.8kg |
| Accessories | Power cable/HDMI cable/DP cable/USB cable/QSG/Warranty card |
| Note | *HDMI2.1 supports PS5 and Xbox Series X at 4K UHD@ 20Hz (4:2:0) |
Gaming-oriented features include “Black Equalizer,” a gamma enhancement which brightens up darker shades to increase visibility. Plus an onscreen crosshair and FPS counter (refresh rate display, reflects FPS with VRR active). The ports are located at the bottom of the screen and include; AC power input (internal power converter), a 3.5mm audio input, 3.5mm headphone jack, 2 HDMI 2.1 ports, DP 1.4 (with HBR3), USB-C (<20W PD assumed, DP Alt Mode, upstream data) and 2 USB 3.0 ports plus upstream.
Sources: GIGABYTE, PC Monitors
