Corsair has announced three new all-in-one liquid CPU coolers for enthusiasts seeking low-noise performance cooling that’s attractively priced and complemented by pretty lighting. Available in a range of radiator sizes, Corsair’s H55 RGB (120 mm), H100 RGB (240 mm), and H150 (360 mm) RGB coolers are equipped with SP120 RGB ELITE fans with AirGuide technology running up to 1,500 RPM and individually addressable RGB LEDs on the pump head and fans that can be controlled via compatible motherboards and their software. These coolers are compatible with nearly all modern Intel and AMD CPUs (e.g., LGA 1200, 115X, 2066, and AM4 sockets) and include a modular, tool-free mounting bracket and pre-applied thermal material for easy installation.
CORSAIR H55 RGB, H100 RGB, and H150 RGB all-in-one liquid coolers offer everything you need to keep your CPU running at peak performance, including fans, coolant, and radiator, in a single closed loop that’s easy to install and maintain. The multiple radiator sizes offered ensure that you’ll find a cooler that will fit your case or style of build. Each cooler is equipped with one, two, or three SP120 RGB ELITE fans, running up to 1,500 RPM with AirGuide technology for concentrated airflow and improved low-noise performance. A thermally optimized copper cold plate and low-noise pump ensure quiet yet efficient cooling.
Source: Corsair
