Philips has announced a new addition to its Momentum line of gaming monitors designed for Xbox. The product line covers many bases for both console and PC gamers with premium features such as 4K resolution, HDR, and variable refresh rates. It seeks to fill the gap between gaming displays and televisions as modern consoles adopt more PC-centric display options.
The new 279M1RV is based on an LG Nano IPS panel and checks off many boxes for gamers seeking a smaller, 27-inch display. It is capable of 4K VRR @ 120 Hz via HDMI 2.1 and up to 144 Hz via DisplayPort 1.4. NVIDIA G-SYNC has limited support through DisplayPort, with an active range of 60 Hz to 144 Hz. The panel covers 98 percent of the DCI-P3 color gamut and features a contrast ratio of 1000:1 and response time of 1 ms GtG. It is DisplayHDR 600 certified with a brightness of 450 cd/m². Connectivity options include 3x HDMI 2.1, 1x DP 1.4, and 1x USB-C. It is presently listed at European retailers with a price of around €845 ($995.84).
LCD panel type: IPS technology
Backlight type: W-LED system
Panel Size: 27 inch / 68.5 cm
Effective viewing area: 603.9 (H) x 347.45 (V) mm
Aspect ratio: 16:9
Maximum resolution: HDMI/DP: 3840 x 2160 @ 144 Hz*; USB-C: 3840 x 2160 @ 120 Hz
Pixel Density: 163 PPI
Response time (typical): 1 ms (Grey to Grey)*
Low Input Lag: Yes
Brightness: 450 cd/m²
SmartContrast: Mega Infinity DCR
Contrast ratio (typical): 1000:1
Pixel pitch: 0.1554 x 0.1554 mm
Viewing angle: 178º (H)/178º (V), @ C/R > 10
Flicker-free: Yes
HDR: DisplayHDR 600 certified
Colour gamut (min.): DCI-P3: 98%*
Colour gamut (typical): NTSC 112%*, sRGB 133%*, Adobe RGB: 110.1%*
Picture enhancement: SmartImage game
Display colours: Colour support 1.07 billion colours
Scanning Frequency: HDMI: 30–135 kHz (H) / 48–144 Hz (V); DP: 30–254 kHz (H) / 48–144 Hz (V); USB-C: 30–254 kHz (H) / 48–120 Hz (V)
LowBlue Mode:Yes
sRGB: Yes
SmartUniformity: 97 ~ 102%
Delta: E< 2 (sRGB)
Ambiglow: 4 sided
G-SYNC: Compatible 60 Hz ~ 144 Hz (DP)*
Adaptive sync: Yes
HDMI 2.1 Feature: VRR, FRL
Signal Input: HDMI 2.1 x 3, DP 1.4 x 1, USB-C x 1 (DP Alt mode, PD 65 W)
USB: USB-B x 1 (upstream), USB 3.2 x 4 (downstream with 2 fast charge B.C 1.2)
Height adjustment: 130 mm
Swivel: -/+ 35 degree
Tilt: -5/20 degree
On mode: 54.9 W (typ.)
Standby mode: 0.5 W (typ.)
Off mode: 0.3 W (typ.)
Product with stand: (max height)609 x 545 x 282 mm
Product without stand: (mm)609 x 353 x 75 mm
Product with stand: (kg)9.00 kg
Product without stand: (kg)5.20 kg
Source: Philips (via TechPowerUp)
