When the Nintendo Switch launched on March 3, 2017, many users were perplexed at why the hybrid console was missing a crucial feature: Bluetooth audio support. For whatever reason, the system did not allow gamers to pair Bluetooth audio devices with it, nor did Nintendo seem to care even after years of complaints.
Luckily, Nintendo has finally addressed this long-standing oversight with its latest Nintendo Switch update, which was made available yesterday. Ver. 13.0.0 enables Bluetooth audio support in the Nintendo Switch, allowing headphones, earbuds, speakers, and other audio devices that connect with Bluetooth to be paired with the best-selling system.
There are some limitations that Nintendo wants Switch gamers to be aware of, however. Only up to two wireless controllers can connect to a Nintendo Switch while using Bluetooth audio; users cannot pair additional wireless controllers until they disconnect the Bluetooth audio device. Bluetooth audio will also be disconnected during local communication, such as when starting a local wireless multiplayer game.
Additionally, only one Bluetooth audio device can be paired at a time, but up to 10 devices can be saved on a Nintendo Switch system. Bluetooth microphones cannot be used, either. Users may also experience audio latency depending on the type of Bluetooth device.
The latest #NintendoSwitch update is now available, including the ability to pair Bluetooth devices for audio output.
— Nintendo of America (@NintendoAmerica) September 15, 2021
For more information, including restrictions on some features while using Bluetooth Audio, please visit the support page: https://t.co/vzAB6lZTDu pic.twitter.com/6J5xcDl5kU
Ver. 13.0.0 (Released September 14, 2021)
Bluetooth audio support was added.
- Headphones, earbuds, speakers, and other audio devices that connect with Bluetooth can now be paired with Nintendo Switch family systems for audio output.
- Bluetooth microphones are not supported.
- Up to two compatible wireless controllers can be connected to the system while using Bluetooth audio.
- Bluetooth audio cannot be used while local wireless communication is active.
- Depending on the Bluetooth audio device, there may be some audio delay.
- For more information, see How to Pair and Manage Bluetooth Audio Devices.
“Update Dock” was added under System in System Settings for Nintendo Switch and Nintendo Switch – OLED Model systems, allowing for software updates to Nintendo Switch docks with a LAN port.
- Dock software updates are not available for Nintendo Switch docks without a LAN port.
- This feature was not added to Nintendo Switch Lite.
- For more information, see How to Update the Dock Firmware.
“Maintain Internet Connection in Sleep Mode” was added under Sleep Mode in System Settings.
- When this setting is enabled, systems with wired internet connections will maintain internet connection even while in sleep mode. This allows for software and add-on content to download to the system while the system is in sleep mode.
- The setting is enabled by default.
- When this setting is disabled, the system will connect to the internet only periodically, which decreases power consumption and delays downloads while in sleep mode.
Note: Systems that are not updated to version 13.0.0 or later behave as if this setting is enabled.
The method to initiate “Calibrate Control Sticks” in System Settings was changed.
- From System Settings, go to Controllers and Sensors, select Calibrate Control Sticks, then fully tilt the control stick in any one direction and keep it tilted for a few seconds to begin calibration.
Users can now view whether their wireless internet connection is using the 2.4 GHz or 5 GHz frequency band under “Connection Status” after selecting Internet in System Settings.
Source: Nintendo
