In this MasterAir MA624 review, we strapped the Cooler Master MasterAir MA624 Stealth to our test bench to see how it performed against other air coolers that we’ve tested. With its unique look and RGB fan, it helps your build look unique compared to your friends while cooling your CPU in the process. So, let’s recap the performance below and see how the Cooler Master MasterAir MA624 Stealth stood up!
Summary of Temperatures
Cooler Master MasterAir MA624 Stealth With AMD Ryzen 7 2700X.
The Cooler Master MasterAir MA624 Stealth was able to operate at its quietest configuration and maintain a temperature of 61.5 degrees Celsius with our test bench running at stock clocks. As we increased the overclock, we were able to keep our AMD Ryzen 7 2700X in check at 4.1GHz at all fan settings.
The Cooler Master MasterAir MA624 Stealth is the first air cooler on our test bench that could keep our overclocked configuration from crashing at minimum fan speeds.
Summary of Sound Levels
Cooler Master MasterAir MA624 Stealth Sound Levels with AMD Ryzen 7 2700X.
At its slowest fan speed settings, the Cooler Master MasterAir MA624 Stealth easily blended in with the ambient room sound levels and we could not hear a thing. At fan speeds greater than that, this unit was generally quiet and competitive with the be quiet! Dark Rock Pro 4.
The Cooler Master MasterAir MA624 Stealth is a very large dual-tower cube with fans that attach to your preferred CPU socket and is about as beefy as the Dark Rock Pro 4 and Noctua D15. It has a 5-year warranty. As it operates on that tier, it gave us high expectations for performance, and quite frankly, it delivered.
Consistent with temperatures, the Cooler Master MasterAir MA624 Stealth was regularly tied with the quietest cooler we have seen to date. This makes the unit very much a top competitor in this aspect of its performance.
When it comes to price we find that the Cooler Master MasterAir MA624 Stealth is available for $99.99 in e-tail. That price point has a number of other comparable coolers making it appropriately priced for the thermal and sound performance that it can deliver.
If you are in the market for one of the best air coolers you can get with your hard-earned dollars, the Cooler Master MasterAir MA624 Stealth should absolutely be on your shortlist.
