Cooler Master has announced its V SFX Platinum power supplies, the company’s first PSUs to feature the new PCIe 5.0 power connector with 12+4 (16) pins.
Comprising both SFX-L and SFX form factor models, Cooler Master’s V1100 (1,100 watts) and V1300 (1,300 watts) Platinum power supplies feature a next-generation power connector that can be clearly seen in some of their marketing shots, which showcase a slightly unusual design with extended connectors. While Cooler Master has yet to confirm the exact specifications of its PCIe 5.0 power connectors, ongoing coverage suggests that they will provide up to 600 watts of power for future GPUs and graphics cards.
Cooler Master hasn’t shared pricing details or dates of availability for its new V SFX and V SFX-L Platinum power supplies yet, but here are links to their individual specification/product sheets:
V SFX and V SFX-L Platinum Power Supplies (Cooler Master)
SFX-L FORM FACTOR
The V SFX-L Platinum delivers the high quality experience you’ve come to expect from the V series in SFX-L form factor. Enjoy the same great features with 80 Plus Platinum efficiency, full-modular cabling, an 120mm fan, 16AWG PCIe high performance cables, and a 10 year warranty. But now you can have this first highest power density of SFX-L PSU in a mini-ITX case. With the V SFX-L Platinum, the V series is now viable for cases ranging from mini-ITX all the way up through E-ATX systems. And with the included bracket this unit is compatible with all of them.
SFX FORM FACTOR
The V SFX Platinum delivers the high quality experience you’ve come to expect from the V series in SFX form factor. Enjoy the same great features with 80 Plus Platinum efficiency, full-modular cabling, an 92mm fan, 16AWG PCIe high performance cables, and a 10 year warranty. But now you can have this first highest power density of SFX PSU in a mini-ITX case. With the V SFX Platinum, the V series is now viable for cases ranging from mini-ITX all the way up through E-ATX systems. And with the included bracket this unit is compatible with all of them.
SUPPORT PCIE 5.0 CONFIGURATION
Designed according to the latest PCIe5.0 specification and Supports data link speed operation of 32GT/s with superior memory, storage capacity and segmentation capabilities to capture higher volumes of upstream and downstream traffic.
80 PLUS PLATINUM CERTIFIED
This certification guarantees a typical efficiency of 92% under normal operating conditions.
